Torque limiters and clanking noise
I had the K-member brace and torque limiters installed today. My car had a little clunking noise in the driveline before, which I just attributed to driveline slop. Now it's a very annoying clanging noise, especially between the 1-2 shift (5-speed). The mechanic said when he test drove the car, he heard it ,and said it is because of the torque limiters not allowing any flex anymore. Is there a fix for this? I plan on ordering an aluminum driveshaft in the future, will that help or make it worse?
Go here https://www.pegasusautoracing.com/pr...p?Product=3066
You will need 2 of the
3066-M10x1.50-Left
Metric Rod End: Male 10mm Bore/ 10 x 1.50 Thread, Left
These will take care of your noise problem for the most part.
An aluminum drive shaft will not help remove the noise the rod ends are making.
I installed these on my car after the stock ones drove me crazy with the noise and this fixed the problem.
3066-M10x1.50-Left
Rando
8/25/21 11:12 AM
