Tokico D-Spec adjustment???
I did do a search but did not find what I am looking for. I just installed Pro Kit and D-Specs on my 07 GT and I am confused about the adjustment.
1) After you go full tight to start your adjustment, it seems when you start loosing (going softer) there is no resistance at all from the **** while turning. Is this how it is for all of you? It just seems wierd.
2) The adjustment for the front seems real wierd. Looking at the manual it looks like the little nut with the red "tokico" rubber cap on it stays on and you them remove just the rubber cap and put the adjuster in. As you know this can't be the case. So it looks like you need to remove this 14mm nut and then put the adjuster in. Why did they not just give the little gold spin on cap that goes on the rear for the front also - very confusing. Anyways, when I remove the 14mm nut on the front and put the adjuster in, it feels real wierd loosening from full hard - NO resistance. Is it working?
Also, I ended up tightening all of them to full hard because I was confused on this and the ride really does not feel that firm. Anyone else on full hard? Also, is it ok to break them in at full hard?
Breeeeeath.
Breeeeeath.
I notice a pretty big difference when going two turns firmer. I have never ran mine at full firm. The closest I have come is 2 out front/3 out rear and it was pretty stiff on broken highway. I can't imagine how it would ride set on full firm.
I don't see why breaking them set on full firm would be harmful (except to your back, neck, etc.) but I honestly do not know.
Yep, you remove any caps from the front and rears and no, there isn't any resistance against the tool when you turn it. make sure you put the caps back on when you're done so that it keeps the dirt out.
so far i've done 4 turns from full firm on both the front and rears. i did four turns (front) and 3 turns (rear) at first but the rear was a bit too stiff. i'll see how it goes from here.
good luck, they are awesome!
I have adjusted mine though just about all the setting and have found that 5 turns from full out back and 4 turns from full up front give a very nice ride. Anything less and it is to floaty feeling and anything to harder make the ride a bit to harsh. If i was going to take the car on same back winding roads i would most likely set them both to 3 turns from full. Also make sure you do not go more than the 7 full turns from hard or you will remove the adjuster and wreck the shocks. I also go to full hard prior to each adjustment to make sure everything start and ends equally.
Richard
Richard
I only ask because I have a set of drag shocks for my chevelle and you adjust it so the front shocks extend very easily but are hard to compress and the rear shocks are harder to compress allowing for a better weight transfer to the rear wheels. Do the Tokico D-Spec adjust like this or does it not allow for a difference between compress and extension on the same shock?
Richard
Richard
Richard
whats the best set up for drag racing? I'm thinking about picking these up for my 07 GT/CS when it arrives.
Here is a great post, on another forum about settings for the D-Specs on the S197. One person seems to be getting good results at the drag strip with the front set at 6 3/4 and the rear set at 6 out from full firm. I ran mine at 6F/4R the last time I went to the track and I was able to hook up pretty good. I am going to try the 6 3/4F/6R the next time I go out and see how that goes.
The Tokiko D-Specs adjust the compression and rebound at the same time. They are not adjustable independently.
9/16/15 07:44 PM
