Tire Pressure?
Old Jan 15, 2007 | 03:54 AM
nickvaz's Avatar
Tire Pressure?
I'm running 20x8.5 with 255/35/20 and 20x10 with 275/35/20. What's the correct tire pressure?
Old Jan 15, 2007 | 06:43 AM
KdF's Avatar
KdF
35psi.
read the Door Jamb. Really does not matter what size tires as the car was developed for tires at the pressure stated on the Jamb.
Racing , etc...etc..may use different pressures , but for street driving....35psi.
Old Jan 15, 2007 | 03:00 PM
metroplex's Avatar
My door sticker says 32 psi for 235/55R17 tires.
Old Jan 15, 2007 | 09:09 PM
RadBOSS's Avatar
For the low profile tire you have, for street you might consider higher pressures. Remember the section height is much shorter so the tire has less deflection capacity before you pinch it on the rim. My Volvo with 45 series takes 38 psi with full vehicle load and that ain't enough.
Rando
Aug 25, 2021 11:12 AM
