Tillman Speed - Whipple's for $200 off! Group Purchase!
Old Sep 16, 2008 | 09:43 AM
TillmanSpeed's Avatar
Former Vendor
We're trying to get these kits at a more reasonable price for you guys. In order to do this, we must hit 7 kits!
The closest competitor would be $6488.99! We're offering ANOTHER $200 OFF that price if we can get this group purchase done. This includes all mustangs from 2005-2007!
This is the HO kit, in black finish! Add $320.00 for polished!
We have to hit 7 kits here, and yes they are the 3.5" pulley for 10+ PSI! Kit comes complete with everything from Whipple!
GT500 Dual In-Tank Fuel System
Spark Plugs (HT0)
Heat Exchanger
Intercooled 10PSI HO Charger
Pulleys, Belts, Harware, etc.
Whipple Intake/MAF Assembly
Ford Racing ProCal Tool!
WE INSTALL IN-HOUSE AND CAN CUSTOM TUNE USING SCT's ADVANTAGE III SOFTWARE!
INSTALLS IN-HOUSE STARTING AT JUST $650! TUNING STARTING AT $150 w/CUSTOMER SUPPLIED XCAL2 or X3!
NOW SHIPPING
Whipple Superchargers have paved the way for forced induction applications over the years and truly set the industry standard when it comes to power, reliability and overall customer satisfaction. Whether your looking for a daily driver that needs a little more punch or your craving a tire-frying, rubber shredding street machine, the Whipple Supercharger Ford Racing systems delivers like no other SC system today. Power from tip in to redline, the new Whipple SC system makes over 40% power across the entire rpm range while maintaining industry leading drive-ability. The incredible HO system produces nearly 75% more power across the entire rpm range!
With years of OEM and racing experience, Whipple and Ford engineers have developed a unique PCM calibration that reconfigures all the necessary engine functions including fuel, spark, knock detection, torque management, transmission control and electronic throttle control. The Whipple-FRPP PCM calibration set such new standards for engine control and monitoring that some 08’ model OE vehicles will be adapting to the new software. The vehicles PCM constantly monitors the engines torque output while monitoring many different parameters to keep the engine in it’s ideal parameters. If a parameter falls below specification, the PCM will lower boost and torque output until the problem can be cured. No other calibration in the field has such technology, giving the Whipple-FRPP SC system unheralded performance and reliability.
HO SYSTEM
While 415HP might be enough for some, Whipple and Ford Racing have also developed the biggest, baddest intercooled system available today. The HO system boasts a massive aluminum air-to-water intercooler with a bar/plate design and 19fpi. This enormous intercooler mounts inside the cast aluminum long runner Whipple intake manifold. The air-to-water system stays cool with an oversized Fluidyne heat exchanger, nearly twice the size of some of the competition. A Shelby GT500 high-flow fuel pump takes care of the extra fuel flow while the Ford Racing PCM flash tool reconfigures the factory PCM for incredible, reliable power. The HO package pumps out an astonishing 500+HP* and over 475+TRQ*, all on 91-octane pump gas and a 100% stock engine! You’ll make nearly 400RWTRQ at the hit of throttle with an instant 8lbs of boost, something turbo and centrifugal systems simply cannot do.
EXCLUSIVE FEATURES:
  • Instant boost, zero lag time for incredible throttle response
  • Revolutionary W140ax Whipple twin-screw supercharger
  • Massive 5” thick aluminum intercooler for superior cooling
  • Oversized Fluidyne heat exchanger for increased cooling capacity
  • Ford GT 38lb/hr fuel injectors
  • 0 degree Ford Racing spark plugs
  • Twin screw supercharger is the most efficient SC on the market
  • Exclusive TRUE cold air intake system with 9” S&B “True-flow” filter
  • Self contained oil system, no tapping oil pan
  • Industry leading 95mm mass air flow meter
  • Exclusive cold air intake system with 9” S&B “True Flow” filter
  • Ford Racing flash programmer for industry leading power, reliability and durability
  • Zero tuning required, all pre-set
  • Available non-intercooled and intercooled
  • Available for manual and auto transmission equipped vehicles
TILLMAN SPEED - IN-HOUSE DYNOJET 224xLC
WHIPPLE SUPERCHARGERS GROUP SALE
www.TILLMANSPEED.com
610-497-5776 or 610-497-3736
ASK FOR CHRIS ROSE!!!
Jul 8, 2016 08:53 AM
Mustang65bob
Sep 21, 2015 11:30 AM
samjluck
Sep 17, 2015 10:24 PM
robjh22
Sep 8, 2015 12:31 PM
