Throttle vs. Battery
First, I want some clarification.
If I disconnect only the negative terminal of the battery, what does this clear in the computer? I've never found a definitive list of things that will get reset when you do that.
Second, when I disconnect the negative terminal, after reconnecting, do I need to do the throttle reset proceedure?
Sometimes I just wish we all went back to cable-controls. Less confusing and less black-box.
It clears the computer's KAM(keep alive memory) which deletes its long term memory's WOT timing and A/F ratios, and the max rpm and max speed that was attained. Also deleted are the radio's settings.
Doing the throttle recalibration is a good idea.
than you either did not properly diconnect the battery or you diconnected the wrong terminal, because there should be no powerer going to the car in order for it to keep that info. Another thing may be that you did not disconnect for long enough.
Definately the negative (black cable), definately undone.
When I reconnect, the horn beeps, and the radio changes to the AM mode, but none of the presets are changed. All my keys still hit the same stations.
Strictly from an electrical perspective, it doesn't matter which terminal you disconnect. You're opening the circuit and no current can flow. The negative is preferred because there's no risk of a short if your wrench touches a ground point.
My guess on the computer is that certain info is saved to Non-Volatile RAM. Once the data is written, it stays there until it is overwritten.
http://en.wikipedia.org/wiki/NVRAM
I disconnected the battery when I installed my CAI. It took a couple more seconds to start, but that's about all. I didn't reset anything. Should I have?
Car runs fine!
Car runs fine!
To be honest, I haven't noticed if the clock was off. Hmm...I guess that means....
BRB!!!
PonyMuscletang13
Sep 29, 2015 09:40 AM
Sep 23, 2015 03:21 PM
