Suspension did fail. BMR LCA let go!!!
Old Jun 26, 2006 | 07:04 PM
cop on my back's Avatar
Thumbs down Suspension did fail. BMR LCA let go!!!
Well after regreasing the bushings in hopes that that would solve the suspension issue I drove to work today and it was down right scarey. I hardly had to give it gas and the rear end was all over the place.
I limped it home and pulled out the passenger side LCA and as I suspected, the bushing was split on the front end allowing the steel sleeve to move back and forth. They have been installed for 3 months and I don't drag race.
I will post pictures after I get all cleaned up, but all of you out there with BMR LCAs if your rear end seems off a bid you better pull them out. I sent an email to BMR today about the suspected issue but now after pulling them out I am sending them a picture to show the failure. I hope they will replace it!
Attached Thumbnails Suspension did fail.  BMR LCA let go!!!-100-0071_img.jpg   Suspension did fail.  BMR LCA let go!!!-100-0072_img.jpg   Suspension did fail.  BMR LCA let go!!!-100-0073_img.jpg   Suspension did fail.  BMR LCA let go!!!-100-0074_img.jpg
Old Jun 26, 2006 | 10:56 PM
94tbird's Avatar
holy crap im worried about my car now cause i got those too and i DO drag race.
Old Jun 26, 2006 | 11:09 PM
official_style's Avatar
this is why i am not screwing with my suspension! glad your OK!
Old Jun 27, 2006 | 06:05 AM
SoFlaBoss's Avatar
I have a set of BMR LCA's waiting to be installed for many months now. This has me very concerned!
Old Jun 27, 2006 | 08:16 AM
dustindu4's Avatar
9 is not my lucky number.
The stock LCAs can do the same thing
Old Jun 27, 2006 | 12:08 PM
SonicBlue05's Avatar
This is why I use Ingalls Engineering arms, FORGED ENDS!
Old Jun 27, 2006 | 05:58 PM
In 3 months???!!! I don't think so.
Old Jun 27, 2006 | 05:59 PM
The ends of the steel portion are fine, it is just the bushing that failed.
Old Jun 30, 2006 | 07:45 AM
Got a reply from BMR. They are sending me a set of 4 bushings for my LCAs. Glad they are willing to stand behind their product
Old Jun 30, 2006 | 04:50 PM
2005MineralGT's Avatar
Just curious, what kind of grease did you use when you installed them? Normal petroleum based grease will break down polyurethane bushings. That is why they recommend a silicone based or synthetic grease. I am not sure if that has anything to do with your failure, but I just figured it would be good to know since there are a lot of us out there with those same parts.
Old Jun 30, 2006 | 09:59 PM
I used a marine grease. It has very good resistance to wash out.
Old Jul 1, 2006 | 03:50 AM
BG_S197_GT's Avatar
I bought a cartridge of silicone grease and a new grease gun from Summit for the reason 2005MineralGT states regarding material incompatibility. I have a BMR panhard rod with polyurethane bushings. Whats interesting is that BMR originally recommended marine grease to me. I then did some research using the Dow Corning material data sheets and a few other sources. But still, 3 months seems too quick.
Old Jul 2, 2006 | 03:58 AM
300HPGT's Avatar
well I hope that this dosnt happen to me. I just invested my money into LCA's, and Panhard rod from BMR. All with Poly bushings. I did buy it with the grease that they sell with the kits. So hopefully I dont have this problem.
Old Jul 2, 2006 | 08:37 AM
I am going to talk to them again regarding what grease to use. As previously posted, if the marine grease that I was using is non-compatable with the poly bushing material, I better change it!
I am going to go ahead and change the grease nipples to stainless ones while I am at it. I found the little check ball in the end of the nipple let grease squirt back out after you remove the grease gun. I think there was only one that didn't "leak".
Old Jul 2, 2006 | 07:29 PM
emperorjordan's Avatar
I want to see how this unfolds. and I just got my BMR stuff too. ****it.
Old Jul 3, 2006 | 11:58 AM
FireFighterHill's Avatar
BMR has a good reputation. Id just take it as a bad bushing and if they are sending you new ones then be happy. If you dont trust them ask them to take the old ones and give u a refund or maybe they be willing to completly replace them.
Old Jul 3, 2006 | 03:57 PM
Sonic05's Avatar
So far so good with mine. I have a feeling this was just a freak failure. I could have been the grease, but that would mean the grease broke down the rubber pretty quick.
I would like to see the new ones if you can take a pic. I've been wondering how they are constructed and how the grease flows through them.
Old Jul 3, 2006 | 04:54 PM
I will post a picture of the new ones. BMR said that if it does it again from autocrossing they will take mine back and give me a really good deal on the solid hime (sp) joint style.
Old Jul 6, 2006 | 10:30 AM
dustindu4's Avatar
After reading this thread I decided to take my LCAs off and check the bushings. Sure enough, 3 out of the 4 bushings were completely destroyed. I guess I have to call BMR too.
Old Jul 6, 2006 | 04:27 PM
Sonic05's Avatar
Uh oh, lately I've thought the rear of my car sometimes feels loose. I just had the rear of the arms off, so I know they are fine, but what about the other ends? I'm getting worried. How many more people are going to find problems?
