Suspension did fail. BMR LCA let go!!!
1 Post
Well after regreasing the bushings in hopes that that would solve the suspension issue I drove to work today and it was down right scarey. I hardly had to give it gas and the rear end was all over the place.
I limped it home and pulled out the passenger side LCA and as I suspected, the bushing was split on the front end allowing the steel sleeve to move back and forth. They have been installed for 3 months and I don't drag race.
I will post pictures after I get all cleaned up, but all of you out there with BMR LCAs if your rear end seems off a bid you better pull them out. I sent an email to BMR today about the suspected issue but now after pulling them out I am sending them a picture to show the failure. I hope they will replace it!
1 Post
Originally Posted by SonicBlue05
This is why I use Ingalls Engineering arms, FORGED ENDS!
Just curious, what kind of grease did you use when you installed them? Normal petroleum based grease will break down polyurethane bushings. That is why they recommend a silicone based or synthetic grease. I am not sure if that has anything to do with your failure, but I just figured it would be good to know since there are a lot of us out there with those same parts.
I bought a cartridge of silicone grease and a new grease gun from Summit for the reason 2005MineralGT states regarding material incompatibility. I have a BMR panhard rod with polyurethane bushings. Whats interesting is that BMR originally recommended marine grease to me. I then did some research using the Dow Corning material data sheets and a few other sources. But still, 3 months seems too quick.
well I hope that this dosnt happen to me. I just invested my money into LCA's, and Panhard rod from BMR. All with Poly bushings. I did buy it with the grease that they sell with the kits. So hopefully I dont have this problem.
1 Post
I am going to talk to them again regarding what grease to use. As previously posted, if the marine grease that I was using is non-compatable with the poly bushing material, I better change it!
I am going to go ahead and change the grease nipples to stainless ones while I am at it. I found the little check ball in the end of the nipple let grease squirt back out after you remove the grease gun. I think there was only one that didn't "leak".
BMR has a good reputation. Id just take it as a bad bushing and if they are sending you new ones then be happy. If you dont trust them ask them to take the old ones and give u a refund or maybe they be willing to completly replace them.
So far so good with mine. I have a feeling this was just a freak failure. I could have been the grease, but that would mean the grease broke down the rubber pretty quick.
I would like to see the new ones if you can take a pic. I've been wondering how they are constructed and how the grease flows through them.
1 Post
After reading this thread I decided to take my LCAs off and check the bushings. Sure enough, 3 out of the 4 bushings were completely destroyed. I guess I have to call BMR too.
Uh oh, lately I've thought the rear of my car sometimes feels loose. I just had the rear of the arms off, so I know they are fine, but what about the other ends? I'm getting worried. How many more people are going to find problems?
