Strut tower brace question....
Old Sep 13, 2008 | 03:53 PM
Starfleet007's Avatar
Is there any gain in support going with brace that uses all four bolts on each tower vs. one that uses 2 on each? I don't see a lot of 8 bolt braces, mostly 4 bolt.
Old Sep 13, 2008 | 06:12 PM
"They say" the s t b only helps slightly to firm things up. That being said I would say that using all 4 bolts on each side would be for looks only. Please correct me if I'm wrong. <-----disclaimer
Old Sep 13, 2008 | 06:58 PM
karman's Avatar
You are pretty much correct.
It may reinforce the top of the shock tower mounting though.
I don't think that it really needs more strength either.
Old Sep 13, 2008 | 07:04 PM
FLAstangx3's Avatar
Correcto'. To really Brace it, you should add an A-Arm Brace underneath also. Two bolts up=top is adequate for what it does.
Old Sep 14, 2008 | 07:46 AM
pebkac's Avatar
Ditto on this!!! also on the 4 vs. 8 debate. I would go with 4 after my experiance. I have an 8 I put on about 1.5 years ago. I just noticed that my camber is off pretty bad. It corners really nice but the inner half of my fronts are worn a 32'nd or more than the outer half. I have not looked into what is causing it, but I am assuming that when I put my STB on, the top of the struts moved since I had to take all four nuts off to get my brace on.
Old Sep 14, 2008 | 09:03 AM
Robbieg's Avatar
That's a great point!
Old Sep 14, 2008 | 10:13 AM
karman's Avatar
That is an assumption of course.
I took great care to make sure nothing moved when I installed mine.
One more question. What are you going to do about it, no matter what caused it?
Old Sep 14, 2008 | 09:25 PM
pebkac's Avatar
For the moment nothing. In a month or so I will put it up on stands an look it over. I need to read about it and try to figure out how to measure how far it is out. More for the knowledge, as I could just go down the street and have it fixed in 30 min. I just noticed it last week and I only drive it 1-2 times a week. Worst case I get a camber bolt/kit/plate and call it a day.
Old Sep 19, 2008 | 03:36 AM
JedCranium's Avatar
I think the best setup would be a strut tower brace that not only braces the towers (4 or 8 bolt) but also mounts to the firewall. In addition an A Arm brace below. Not every likes the look of the firewall mount. So you have to weigh looks to functionality. Next step would be to upgrade your K-Member and A-Arms, your looking at 1K + for that from BMR.
Jed
Old Sep 19, 2008 | 06:39 AM
05YellowGT's Avatar
Jed , the reason most don't mount to the fire wall , is that the front one that it would attach to is a fake one and doesn't add real support. You'd have to run it through to the back one ...
pebkac , I've had several different braces on and one of them was a four bolt and I too was worried about removing all 4 nuts. There's a hole , or holes I don't remember exactly , with the plate exposed below it. I took a pencil and traced around the hole onto the plate so I would know if it had moved. Mine didn't , but it's a way to tell if it did ...
Old Sep 19, 2008 | 11:52 AM
PIKE2244's Avatar
So the best way to keep it from moving when I install mine is to trace with a pencil? I wish there was a better way...
Old Sep 19, 2008 | 01:01 PM
05YellowGT's Avatar
I didn't say that would keep it from moving , only that if it did move you would be able to tell ...
Old Sep 19, 2008 | 01:08 PM
PIKE2244's Avatar
Yeah sorry I should have clarified... So do you have to take the bolts off to make the marks or are they reachable before you unbolt them?
Old Sep 22, 2008 | 05:49 AM
05YellowGT's Avatar
The hole isn't under a nut or anything , it's about the size of a nickel and you can see the plate through it. I just traced a circle around it on the plate and checked that when I was done. If the car doesn't move the plate shouldn't , and mine didn't. I put the parking brake firmly on and put chocks both behind and if front of my wheel to make sure it didn't ...
Old Sep 22, 2008 | 04:04 PM
PIKE2244's Avatar
That makes sense using chocks down... That will put my mind to ease a bit more. Although, I don't know why I'm worried all that much b/c isn't the worst that could happen is I have to take it in to get realigned???
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
dohc97
Sep 24, 2015 01:52 AM
Sep 16, 2015 06:44 PM
