Strut tower brace
Old Jun 3, 2007 | 08:59 PM
Fman67's Avatar
Strut tower brace
Who sells a Strut tower brace that clears factory plenum cover and doesn't rub hood?
Old Jun 3, 2007 | 09:00 PM
kevinb120's Avatar
Check the V6 ones, the 4.0 sits higher. A single simple bar is more then enough. I'm sure someone's tried it. The 07 has a little more clearance already then the 05-06
Old Jun 3, 2007 | 09:17 PM
Tispco's Avatar
BMR sells a strut tower brace that clears the plenum cover. I have one on my '07 GT that I bought from Ninosport. It clears the plenum cover and hood liner. I have noticed that the '07 hood liner is different from the '05-'06 hood liner, so I can't speak for that.
Old Jun 3, 2007 | 09:34 PM
kevinb120's Avatar
Stoenr has a different shaped one too that clears his
Old Jun 4, 2007 | 11:47 AM
mvon919's Avatar
I have NEW in BOX Ford OEM GT500 STB that goes over plenum and some say it'll clear stock hood also, when adding 2 spacers on the back studs to angle it a little. $70 SHIPPED in Continental US. PM me. Paypal only.
Old Jun 4, 2007 | 01:41 PM
pbeelien's Avatar
I'm using the Steeda unit without any issues...heres a pic
Old Jun 4, 2007 | 05:34 PM
sodaman's Avatar
The BMR is the way to go, heres mine, as you can see clears cover nicely. Barely touches hood liner, you can see two small indents, but you can also tell the hood liner hangs about and inch or more low from the hood. If you dont want it to rub, undo hood liner, 3m adhesive it to the hood put back in pins, and no rub. Awesome Brace. You can add your own emblems etc, stickers are in box not attached. Good luck
Attached Thumbnails Strut tower brace-p1010090.jpg   Strut tower brace-p1010096.jpg
Old Jun 4, 2007 | 06:13 PM
GRAYPNY's Avatar
+1 on the BMR brace. Works like a charm and is nice looking under the hood.
Old Jun 4, 2007 | 07:38 PM
mvon919's Avatar
buy gt500 oem stb from me. 65 shipped. pm me.
Old Jun 6, 2007 | 07:01 PM
odiaz's Avatar
I used the granatelli STB. One trick is to mount the plenum cover underneath the screws in the rear. Normally the PC sits ontop of these screws, but, if you remove them, install the PC and then install the screws back over the PC, you will gain over a 1/4" of clearance.
This may not seem to be a lot but you'd be surprised how much that actually is when you are low on clearance.
Also, be careful with the STB from the 07 and higher cars. Ford modified the Strut tower on the 07s and the STB from these cars won't fit on 05-06 cars.
Old Jun 6, 2007 | 09:12 PM
Fman67's Avatar
Stb
hmmm.what did Ford do to the '07...i have an '07 now...had an '05...what modifications did they do to the strut tower...and which companies make the bar for '07 and up that fit right? Thanks
Old Jun 6, 2007 | 09:20 PM
mrkabc's Avatar
Why waste your time with an STB? It doesn't do anything anyway.
I speak from experience...
Old Jun 6, 2007 | 09:50 PM
TillmanSpeed's Avatar
Former Vendor
I have both the Steeda and BMR strut tower braces in stock ready to ship, and honestly... they're both nice pieces! Give us a call if you need any help, and let's see if there isnt something we can do for you!
Cr
Tillman Speed
610-497-3711
Old Jun 11, 2007 | 12:43 AM
07 HOSS Mustang's Avatar
OK who makes a STB for the Saleen S/C? I saw a pic somewhere. It actually went thru the opening below the top of the S/C.....
07 HOSS
Old Jun 11, 2007 | 10:53 AM
mvon919's Avatar
07 HOSS
steeda billet. you need to have aftermarket engine mounts too. not recommended.
Old Jun 11, 2007 | 12:48 PM
RobK's Avatar
You're just not driving it hard enough.
Old Jun 11, 2007 | 04:10 PM
goldenpony's Avatar
Stb
I have the STB from Strange Development and an aftermarket plenum cover- no problems at all.
Old Jun 11, 2007 | 04:53 PM
Old Man Stang's Avatar
strut bar
www.strangedevelopment.com check there site.
Old Jun 11, 2007 | 06:52 PM
mitch e's Avatar
I read there was a change in motor mounts which caused the engine to sit higher. mitch e
Old Jun 11, 2007 | 07:18 PM
davisinla's Avatar
Neither does the plenum cover.
