STRT shocks?
Old Mar 25, 2011 | 10:28 PM
jaguarking11's Avatar
STRT shocks?
Ended up buying a set of str.t shocks but when I opened up the box the rear shocks dont have the bushings for the rear, nor do they have the nuts.
This is normal? I had replaced the stock ones with a set of monroe shocks and they came with all those little parts. But a much more expensive set does not? Am I missing something here?
In any case what did you guys do for this? I need to do my install next weekend it seems. Any advice?
Old Mar 25, 2011 | 11:06 PM
grabberorange1's Avatar
I have a new set of Koni's as well...just opened the boxes and mine doesn't have them either....
Old Mar 26, 2011 | 06:06 AM
Mine came with out mounting hardware also. I used the old stuff. Don't really think it wore out much. I'm guessing they think it hasn't wore much either. Maybe if they were all dry rotted I would replace that stuff, but that won't happen for more than a few years.
Old Mar 26, 2011 | 03:05 PM
70MACH1OWNER's Avatar
My rear Koni's were the same. No hardware...used the stock stuff.
Old Mar 27, 2011 | 08:51 PM
Dixie_Flatline's Avatar
My STR.Ts came that way as well. I had four winters on my stockers when I replaced them last week, the stock bushings were fine. Swap em out.
They ride like a dream.
Join us.
It's bliss.
Old Mar 27, 2011 | 09:24 PM
Join us.
It's bliss.
GOOD to hear...installing mine next Saturday...I can't wait, I've been wanting to do this for almost 5 years...
Old Mar 28, 2011 | 08:13 PM
Looks like im on the hunt for a set of stock rear shock hardware. Offering 30bux for it. In any case, if anyone has some old shocks with the hardware they don't need anymore, send me a message and ill buy the stuff.
Thanks.
Old Mar 28, 2011 | 08:37 PM
elscorcho's Avatar
Just installed mine this weekend, the ride is waaaay better than stock!
Old Mar 28, 2011 | 08:40 PM
You can get the hardware at Autozone...are you wanting rear shocks? Mine only have 15K miles on em...
Old Mar 28, 2011 | 10:45 PM
I just want the rear bushings/washers/nuts. If you have those I would buy them. In any case ill check with autozone and see if they have the parts.
Old Apr 6, 2011 | 11:58 PM
OK here is my review of the str.t & steeda sport springs.
Had them on the car for about a week.
First off, I recommend using the stock rear strut bushings. The source of my squeaking was the monroe bushings. In any case I greased them, FYI, I had to drill the washers for the bushings but the rubber stayed the same.
In the front I used gt500 mounts, The camber on the car is now around -1.4, not bad but the steeda plates should be considered.
The springs feel just about right for the front, the rears could be stiffer. But overall the ride is pretty **** good, the handling of the car is much better than before but still needs improvement, I think a set of properly matched up swaybars should do the tirck.
Overall im happy, these shocks are a stop gap until I finaly get my hands on a set of koni yellows or possibly a set of adjustable KW's
Overall for the money spent, they don't disappoint. Don't expect them to perform as well as a fully adjustable set. But for a street car they are very nice.
ricky1728
Feb 11, 2016 07:25 PM
bones302
Oct 7, 2015 04:42 AM
GeoWett
Sep 30, 2015 06:40 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
