Stock H pipe removal?
Just curious if there are any tricks that any of you have for removing the stock h pipe? What tools did you use? I've searched but only came up with 96-04 results. I have a slp catted x that I will be putting in its place. My car is at my local Ford dealership getting the engine replaced due to a broken rocker arm so the h pipe bolts shouldn't be seized or rusted. Thanks in advance.
Because it should be done tomorrow and the X pipe is 40 miles away and I won't be able to put it in till the weekend. It's a 07 GT.
Gotcha. I would just be sure to spray them with a good rust penetrent and they should come off fine if not use a little heat to help at least on the catback side I would hope they come off the manifold side easy after having the engine out. Enjoy your mid pipe when you get it in!
Ok so I tried swapping out the h pipe and 3 nuts came out no problem and the 4th one stripped out on me after 2 hours of fighting with it. I used wobble extensions, deep well sockets, impacts, pb blaster, etc and nothing. The nut made it till 2 threads were left then stopped. It was the inside nut on the drivers side. I will take it to a shop and have them remove it then I will do the rest unless they will swap it out for less than $50. Lol
Off-Topic Chatter
9/1/15 09:05 AM
