Steering wheel shimmy
Old Apr 8, 2007 | 07:02 AM
70MACH1OWNER's Avatar
Hi Guys,
About a year ago I started a thread about a slight steering wheel shimmy I had. It would usually only occured after the car sat for several hours in cooler or cold conditions. It seemed once the stock tires warmed up and got round again that it went away for the most part. Someone back than told me that the stock Pirelli's have some nylon in them and would flat spot after sitting. Well, since I have been running my new Steeda Pentars and Nitto 555's for about a month now I still have the same issue. Only this time it doesn't seem to go away. It only happens when cruising around 60-65 mph. I purchased these tires and wheels direct from Steeda mounted and balanced so it seems if 2 sets of tires and wheels have the same issue I must have another problem. I know it would seem that it is a balance issue to most and I would agree. I think I may just put the stockers back on today and take it for a good front end alignment to see if that helps. Any body else having this type of problem and did you get it fixed?
Thanks for the help.
Scott
Old Apr 8, 2007 | 07:09 AM
blkstang06's Avatar
Hi Guys,
Scott
Scott I got the same issue with the FR500's I put on at about the same speed!.... But next week I'm putting knew springs and dampers on after I get the front end aligned I hoping it will be gone..
Old Apr 8, 2007 | 07:20 AM
2L8IWON's Avatar
I had the exact same issue when I got my Foose wheels. Take your wheels off and check your wheel studs. If there are little washer looking things with small tabs on them take them off. These are ised by the factory to keep the rotor on the car during assembly.
What this does for your aftermarket wheels is it keeps them from 100% mate up with your brake assembly.
Check it out and if you have them I gurantee that this will fix your issue.
- Jess
Old Apr 8, 2007 | 07:22 AM
Did you have the problem with the stockers?
Old Apr 8, 2007 | 07:30 AM
blkstang06's Avatar
Not as noticeable! It is worse with the FR500's + 255 45 18's on
Old Apr 8, 2007 | 07:34 AM
I agree. Mine is worse now with the Steeda Pentars and Nitto's. I expected it to go away with the new wheels and tires but it seems it has gotten slightly worse. Bugging the poo out of me now.
Old Apr 8, 2007 | 07:35 AM
blkstang06's Avatar
- Jess
I'll check it out today!........Thanks!
Old Apr 8, 2007 | 07:37 AM
tom281's Avatar
I guess I haven't noticed any shimmy with the stockers, but I'll remember this when I put on the 18" dd bullitts.
Old Apr 8, 2007 | 07:41 AM
- Jess
I also will check this out today. I am going to put the stockers back on today so I can take it for a front end alignment this week. I don't want to take the chance of getting my Pentars scratched up. But I still have the issue with the stock wheels and tires. Did you?
Scott
Old Apr 8, 2007 | 07:45 AM
blkstang06's Avatar
Wow! Tom you got Double D'S or is the deep dish!........
Old Apr 8, 2007 | 07:46 AM
tom281's Avatar
Haha if I had the real DD's, I'd be spending much less time on this computer!
Old Apr 8, 2007 | 07:48 AM
2L8IWON's Avatar
Scott
I never put my stockers back on, so I can't answer that one... If this doesn't fix it though I would go to a good local mom and popalignment shop and see what they have to say.
Good luck man
Old Apr 8, 2007 | 07:56 AM
Old Apr 8, 2007 | 07:57 AM
blkstang06's Avatar
[quote=70MACH1OWNER;886288]I also will check this out today. I am going to put the stockers back on today so I can take it for a front end alignment this week. I don't want to take the chance of getting my Pentars scratched up. But I still have the issue with the stock wheels and tires. Did you?
Scott[/quote Scott are you afraid to leave the drive!.....With those fancy pantsy Steeda wheels.
Old Apr 8, 2007 | 08:02 AM
[quote=blkstang06;886297]
No... but I am afraid of that gizmo they clamp on your rim to do an alignment.
Old Apr 8, 2007 | 08:11 AM
blkstang06's Avatar
[quote=70MACH1OWNER;886301]
I don't like gizmo's clamped to my rim either!.
Old Apr 8, 2007 | 09:53 AM
SC67Stang's Avatar
- Jess
What 2L8IWON suggests will fix the problem in most cases.
I also had the same thing happen with the FR500's and 255/45 18's on mine.
After taking off the washers it went away.
Old Apr 8, 2007 | 11:11 AM
RadBOSS's Avatar
Assuming the wheel stud spring clips are not in the way, its possibly one or combination of several things.
a) wheel balance
b) wheel and/or tire run out (how round is the mounted infalted tire?)
c) stiffness variation
also;
c) not likely with a new mounted tire, but cupping ... which generally only gets worse onces its started.
Some of the tire shops have a very special tire / wheel balancing machine. I have not had the occasion to ask for it yet, but Discount Tire is one of the shops who have them. Might be worth invesigating if you have not already.
http://www.discounttire.com/dtcs/infoRideMatch.dos
also see;
http://www.discounttire.com/dtcs/infoTireBalancing.dos
Old Apr 8, 2007 | 11:39 AM
RobK's Avatar
Are the new wheels absolutely hubcentric? If not you'll need centering rings. That'll cause an issue. Since most folks upsize when they do a wheel/tire swap you might amplify an existing issue with the wider/lower profile tires. You'd be amazed how much tires themselves dampen suspension vibrations/shimmys. If the problem existed with stockers and worsened with bigger aftermarket wheels/tires you might have a bum control arm bushing.
Old Apr 8, 2007 | 01:41 PM
At close to 300 bucks each for the Steeda Pentars I would surely hope so but I can not prove it. I do have the equipment at work I can bring home and prove it one way or the other if needed.
Scott
