Steering wheel shimmy
Hi Guys,
About a year ago I started a thread about a slight steering wheel shimmy I had. It would usually only occured after the car sat for several hours in cooler or cold conditions. It seemed once the stock tires warmed up and got round again that it went away for the most part. Someone back than told me that the stock Pirelli's have some nylon in them and would flat spot after sitting. Well, since I have been running my new Steeda Pentars and Nitto 555's for about a month now I still have the same issue. Only this time it doesn't seem to go away. It only happens when cruising around 60-65 mph. I purchased these tires and wheels direct from Steeda mounted and balanced so it seems if 2 sets of tires and wheels have the same issue I must have another problem. I know it would seem that it is a balance issue to most and I would agree. I think I may just put the stockers back on today and take it for a good front end alignment to see if that helps. Any body else having this type of problem and did you get it fixed? Thanks for the help. Scott :dunno: |
(Post 886265)
Hi Guys,
I had the exact same issue when I got my Foose wheels. Take your wheels off and check your wheel studs. If there are little washer looking things with small tabs on them take them off. These are ised by the factory to keep the rotor on the car during assembly.
What this does for your aftermarket wheels is it keeps them from 100% mate up with your brake assembly. Check it out and if you have them I gurantee that this will fix your issue. - Jess |
Originally Posted by blkstang06
(Post 886269)
Scott I got the same issue with the FR500's I put on at about the same speed!.... But next week I'm putting knew springs and dampers on after I get the front end aligned I hoping it will be gone..:rolleyes:
Did you have the problem with the stockers? |
(Post 886274)
(Post 886281)
Not as noticeable! It is worse with the FR500's + 255 45 18's on
Originally Posted by 2L8IWON
(Post 886272)
I guess I haven't noticed any shimmy with the stockers, but I'll remember this when I put on the 18" dd bullitts.
(Post 886272)
What this does for your aftermarket wheels is it keeps them from 100% mate up with your brake assembly. Check it out and if you have them I gurantee that this will fix your issue. - Jess Scott |
Originally Posted by tom281
(Post 886287)
Haha if I had the real DD's, I'd be spending much less time on this computer! :rofl2:
(Post 886288)
I also will check this out today. I am going to put the stockers back on today so I can take it for a front end alignment this week. I don't want to take the chance of getting my Pentars scratched up. But I still have the issue with the stock wheels and tires. Did you?
Scott Good luck man |
(Post 886291)
[quote=70MACH1OWNER;886288]I also will check this out today. I am going to put the stockers back on today so I can take it for a front end alignment this week. I don't want to take the chance of getting my Pentars scratched up. But I still have the issue with the stock wheels and tires. Did you?
Scott[/quote:lol: Scott are you afraid to leave the drive!.....With those fancy pantsy Steeda wheels. :jester: |
[quote=blkstang06;886297]
(Post 886288)
[quote=70MACH1OWNER;886301]
(Post 886297)
No... but I am afraid of that gizmo they clamp on your rim to do an alignment. :grin: |
(Post 886272)
What this does for your aftermarket wheels is it keeps them from 100% mate up with your brake assembly. Check it out and if you have them I gurantee that this will fix your issue. - Jess I also had the same thing happen with the FR500's and 255/45 18's on mine. After taking off the washers it went away. |
Assuming the wheel stud spring clips are not in the way, its possibly one or combination of several things.
a) wheel balance b) wheel and/or tire run out (how round is the mounted infalted tire?) c) stiffness variation also; c) not likely with a new mounted tire, but cupping ... which generally only gets worse onces its started. Some of the tire shops have a very special tire / wheel balancing machine. I have not had the occasion to ask for it yet, but Discount Tire is one of the shops who have them. Might be worth invesigating if you have not already. http://www.discounttire.com/dtcs/infoRideMatch.dos also see; http://www.discounttire.com/dtcs/infoTireBalancing.dos |
Are the new wheels absolutely hubcentric? If not you'll need centering rings. That'll cause an issue. Since most folks upsize when they do a wheel/tire swap you might amplify an existing issue with the wider/lower profile tires. You'd be amazed how much tires themselves dampen suspension vibrations/shimmys. If the problem existed with stockers and worsened with bigger aftermarket wheels/tires you might have a bum control arm bushing.
Originally Posted by RobK
(Post 886449)
Scott |
