Steeda Ultra Lites???
Old Apr 9, 2007 | 11:24 AM
fivestring45's Avatar
Question Steeda Ultra Lites???
Okay...so I have a set of these sitting in my living room. I'm planning on installing them soon but have a question. How many people with these springs had to actually get the camber bolts installed?
Old Apr 9, 2007 | 12:29 PM
jayguy's Avatar
I had them done by a friend, and he said they were barely out of spec before he did any aligning, so the cam bolts weren't needed.
Old Apr 9, 2007 | 12:45 PM
tx2005gt's Avatar
i did them myself. aligned it by eye and than took it to a friends shop & put it on the alignment machine. it was wright on spec. no adj. bolts needed.
Old Apr 9, 2007 | 02:09 PM
NJ3's Avatar
NJ3
Mine just needed a toe adjustment.
Old Apr 9, 2007 | 05:53 PM
itsmetoo's Avatar
No camber bolts for me either.
Old Apr 9, 2007 | 07:04 PM
ryan1112's Avatar
None for me. Just barely out when I got an alignment.
Old Apr 9, 2007 | 08:13 PM
Fryguy's Avatar
For those of you who did it yourselves, how hard was it. I am looking to get these as well and was just wondering what I would be getting myself into.
Old Apr 9, 2007 | 09:29 PM
ryan1112's Avatar
I watched my mechanic do it. If I had his tools I could have done it myself. An air gun makes using the spring compressor much easier.
Although many people will argue with me, you should pick up an adjustable panhard bar to keep the axle center. After installing the springs I could see the rear axle was off to one side. I installed the Steeda panhard bar and it fixed the problem.
Old Apr 9, 2007 | 09:35 PM
TillmanSpeed's Avatar
Former Vendor
Spring compression... the one thing I always let the tech's do! I need my limbs and fingers! LOL
Ryan, you're absolutely correct on the Panhard bar correcting the axle offset.
Old Apr 9, 2007 | 09:53 PM
Cali HP addict's Avatar
Haha, just got an allignment today. Camber was -1.2 and -1.5 which will help cornering ability but won't affect tire ware. Toe will need to be adjusted though like others have said. Also, I have the added weight of the SC on the front.
Old Apr 9, 2007 | 11:24 PM
LEO_06GT's Avatar
No camber bolts here either.
Old Apr 10, 2007 | 06:06 AM
traffic142's Avatar
me either
Old Apr 10, 2007 | 09:04 AM
For those with the panhard bar, is this more of a cosmetic thing or does it actualy have some performance properties?
Old Apr 10, 2007 | 09:41 AM
Hi Jeff! Look no further!
Steeda Ultralite Lowering Springs Install - REAR
Steeda Ultralite Lowering Springs Install - FRONT
Front End Alignment / Camber info
Other helpful links...
Guide to Properly Lowering your S197 (Very thourough explanation by Galaxie)
Adjustable Camber Bolt Install Video (not required for the Ultralites, but more for reference on how they get installed)
Old Apr 10, 2007 | 11:40 AM
ryan1112's Avatar
TacoBill's instructions are great. If you want to know if you think you can do it, look there.
The panhard bar does help performance. Your car will track better with the rear end center and I noticed the rear end being a little more stable during really hard cornering with the Steeda bar.
Old Apr 10, 2007 | 01:14 PM
Panhard bar? Who manufactures these? Are they called something else on the steeda page?
Old Apr 10, 2007 | 01:32 PM
I heard BMR makes a good one.
http://www.bmrfabrication.com/2005MustangSUSPENSION.htm
About 1/2 way down the page.
I'd install your springs first to see if you even require it.
Old Apr 10, 2007 | 02:24 PM
ryan1112's Avatar
BMR has a good one as Bill said.
Here is the Steeda one.
http://www.steeda.com/products/panhard_bar_brace.php
Old Apr 10, 2007 | 02:38 PM
Former Vendor
We stock the BMR ones, and found those to be great quality, and the best functioning, plus the price is GREAT!
Old Apr 10, 2007 | 04:03 PM
anyone have a picture of one installed on the bottom of the car?
