Steeda UD pulley causing fuse to blow?
Old Jun 18, 2010 | 01:24 PM
SONICBOOST's Avatar
I took my car to my uncles shop to try and fix my A/C issue (not blowing cold air) and he said when they ran all the test the result was the compressor was being spun so fast its blowing a fuse around 3k rpm. Could this be from the UD pulleys? I know plenty of people run these pulleys without that issue so I don't get it. I don't want to have to take these pulleys off to run my A/C. Any ideas on why i'm blowing this fuse. I don't know exactly what fuse it is but it has to do with the compressor for the A/C. Thanks
Old Jun 18, 2010 | 01:27 PM
marc0699's Avatar
Correct me if I am wrong but I always thought a UD pulley ran the accessories slower not faster.
http://en.wikipedia.org/wiki/Underdrive_pulleys
I am however unsure why your AC compressor would be blowing fuses sorry I can't help with that.
Old Jun 18, 2010 | 01:47 PM
SONICBOOST's Avatar
I'm pretty sure it's not the pulleys but i'm at work and my buddy is taking the stock pulleys over to the shop for a pulley swap so well see if the stockers change anything. If not well go from there..
Old Jun 18, 2010 | 05:38 PM
SONICBOOST's Avatar
I have A/C! It ended up being some stupid ac wire that was hanging down exposed and it was causing a short. Now ill be blown cold air on the way to the river this weekend
Old Jun 18, 2010 | 05:58 PM
70MACH1OWNER's Avatar
You are absolutely correct...The UDP's slow down all of the accessories! That ani't the problem.
EDIT....Glad you found the problem Adaaaam!!!
Old Jun 18, 2010 | 06:36 PM
SONICBOOST's Avatar
And all trouble codes are gone Scooooot!
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
