Steeda Tri-Ax Question
Old Dec 28, 2006 | 01:49 PM
kryptonite's Avatar
I just installed the Steeda Tri-Ax in my 05 Mustang GT and noticed that I am having a hard time shifting into 5th and reverse. All other gears are fine. I seem to have to put more effort in shifting into 5th or reverse.
Any ideas????
Old Dec 28, 2006 | 03:13 PM
tom281's Avatar
The Steeda unit and the Pro 5.0 shifter are basically identical. My Pro50 was hard to shift into 5 and R for the first couple hundred miles, then it started to loosen up and now shifts easily. Unless you have the nut that attaches the shift lever to the transmission arm too tight, just give it some time to break in.
Old Dec 28, 2006 | 03:31 PM
kryptonite's Avatar
Thanks!
I thought that might be the case, but wanted to make sure there wasn't an adjustment I missed.
Old Dec 28, 2006 | 03:44 PM
touring's Avatar
yup mine was like that too
but it will get smother with time ,best mod to date
Old Dec 28, 2006 | 04:04 PM
tom281's Avatar
Originally Posted by kryptonite
Thanks!
You're welcome! And welcome to the site!
Old Dec 28, 2006 | 04:15 PM
06GTwJUICE's Avatar
dont forget they include some tiny washers to shim up the rear of the shifter in case you have problems shifting into 5 or R. I never had to use mine.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
