Steeda Shifter
Old Sep 20, 2005 | 12:35 PM
Driver's Avatar
Hello Gang! I have a steeda shifter in my 05 GT. I got a new steeda shift ****, My queston is how does the factory **** come off the factory boot? I sure it is simple but I am having a lttle Trouble. So I am asking the best for the answer. Thanks, Driver
Old Sep 20, 2005 | 12:51 PM
wild stray's Avatar
Just pull the boot down and unscrew it counter clockwise.
Old Sep 20, 2005 | 12:59 PM
Driver's Avatar
Thanks wild stray, I will try that,I did not want to strech the boot out of shape, once the **** is off is it two pieces?
Old Sep 20, 2005 | 01:06 PM
wild stray's Avatar
The **** is just one piece and you might need to secure the shaft a little while removing it the first time so it doesn't turn on you. Remove the boot carefully and it should slide down O.K. Been quite a while since I removed mine, but I don't remember having much of a problem with it.
Old Sep 20, 2005 | 01:09 PM
Driver's Avatar
Thanks for your help, Driver
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
