Steeda pulleys install or trying too
Old Dec 11, 2006 | 10:49 AM
dly's Avatar
dly
Ok the pulleys will be here tomorrow and I though I would start by removing the old pulleys today. I took every thing out of my way and have a clear shot at the bottom crank bolt. 18mm socket, counterclock wise, 1/2" air impact wrech and still it won't budge. Must have empty the 5.5hp 25 gallon air compressor 10 times and its set at 120lbs. The air gun is a little old but it still works on everything else. Is there another 1/2" more powerful gun out there?
help????????
Old Dec 11, 2006 | 10:58 AM
HOTLAP's Avatar
Darrel - that's frustrating......I actually removed the crank bolt on my '05 using my 1/2" Torque wrench....the lenght of the bar really helped with leverage - couldn't budge it with my regulary 1/2" ratchet. Was a struggel though as I had to put the car in gear and crank on the parking brake and the crank still wanted to turn.....
Eleanor Dreaming's Avatar
Try a breaker bar. That is how I got mine off.
Old Dec 11, 2006 | 11:05 AM
neil07gt's Avatar
help????????
Here is a write-up. Try a big torque wrench a gun won't always get it.
http://forums.bradbarnett.net/archiv...p/t-29855.html
Old Dec 11, 2006 | 11:33 AM
Bullitt995's Avatar
2nd most handy tool when coming to cars. First being a sledge hammer of course.
Old Dec 11, 2006 | 12:05 PM
70MACH1OWNER's Avatar
^^^ Me too. Not trying to make you feel stupid but do you have your transmission in 1st gear so the engine can't turn?
Scott
Old Dec 11, 2006 | 12:43 PM
Chilliwack 42's Avatar
+1 on the breaker bar. you could also use a metal pipe and slide it over the breaker bar for some extra leverage. Try some penetrating oil as well.
Old Dec 11, 2006 | 02:56 PM
tom281's Avatar
Try some spinach........
Old Dec 11, 2006 | 05:01 PM
34124231user's Avatar
I don't care who you are, that was **** funny.
Forget the airwrench. Any 1/2" torque wrench will provide sufficient leverage with the car in gear and the parking brake on. Hope you got the right pulley puller! I believe it's the Chrysler puller that works liek a charm, once you get the arms aligned properly. Good luck
Old Dec 11, 2006 | 05:05 PM
jayguy's Avatar
From what I read before, you want the car in a high gear (4th or 5th, not 1st) if you can (if it's a manual). I know from my own experience, in 1st I was still able to turn the engine over by hand and move the car a little. I used a manual impact thing I borrowed from my neighbor, but we got it off eventually.
Old Dec 11, 2006 | 05:07 PM
dly's Avatar
dly
Before I try the impact gun I did try the big breaker bar. The car is in 5th gear and the crank is not slipping or turning over. I've been spraying Nut buster on it for 2 days.
The Mechs here at work told me to heat up the bolt, they are thinking red locite was used??????? I'm worried that I might snap on the bolt head and then I'm F&*#$%.
I'll try again in the morning
Old Dec 11, 2006 | 05:32 PM
tom281's Avatar
In all seriousness, good luck man. All I used was a torque wrench that's about 1.5' long. Hope you get'er done.
Old Dec 11, 2006 | 05:39 PM
dly's Avatar
dly
I hope so the funny thing is I'm no smallguy 6' and 265lb and I lifted weights all though my FireFighting career. But we will give her hell tomorrow.
Old Dec 11, 2006 | 05:52 PM
tom281's Avatar
BTW, I see you're from northern Indiana- I'm just south of Fort Wayne.
Tom
Old Dec 11, 2006 | 05:57 PM
Hold on there partner!! Do not heat that bolt. First off the stock pulley has a rubber center that will melt and be ruined. Second, there is a front oil seal around the snout of the crankshaft that will be the next thing that you will trash. Ford does NOT use locktite on that bolt. No reason to. Be careful. Take it to the dealer if you need too. P.S. Lefty loosey- righty tighty!!
Scott
Old Dec 11, 2006 | 06:05 PM
1st gear and apply the parking brake will work just fine.
Scott
Old Dec 11, 2006 | 06:36 PM
dly's Avatar
dly
Thanks for the infor. I'll make sure I don't heat the bolt. I looked up Harbor Freight tools they got a 25" 1/2" breaker bar or a hi power 1/2" impact wrench I'll probably get in the morning.
I'm from South Bend
Old Dec 11, 2006 | 06:41 PM
tom281's Avatar
I'm from South Bend
Maybe you already know, but here's the local club for your area:
www.michianamustangs.com
Tom
Old Dec 11, 2006 | 06:47 PM
dly's Avatar
dly
Thanks already a member
Old Dec 11, 2006 | 06:59 PM
Import-Slaya's Avatar
I also used my impact wrench at first and it didn't budge. Went to the breaker bar (about 2' long), still no luck. Finally put the 3' tubular handle of my floor jack over the breaker bar and that worked perfectly. Also worked for installation per Steeda instructions (the final torque sequence is pretty tough).
Didn't try spinach, though.
