Steeda inlet elbow for stock airbox?
Will the Steeda inlet elbow work with the stock airbox? Are there any problems with crushing the tube while tightening the hose clamps?
I already had the CAI when I added the inlet pipe. It has two silicone sleeves that allow you to attach it to the TB and the CAI unit. The pipe is solid enough so you can tighten the clamps to secure the pipe w/o breaking it.
If your just planning on purchasing the Steeda inlet elbow ?? you attach the included silicone straps w/clamps onto the stock maf housing side and the other end onto the throttle body, but as I previously mentioned ?? you had better talk with either a tuner or somebody from Steeda tech support first, because I don't think you can safely run a stock tune with a larger intake tube without re-flashing your computer..
M3hunter
9/10/15 09:26 AM
9/8/15 10:45 AM
