Steeda Billet Lower Control Arms
Old Jun 12, 2007 | 01:22 AM
nickvaz's Avatar
I had installed a set of Steeda Billet LCA's a couple of weeks ago along with a adj panhard bar. My traction is phenominal now. The only thing is that I now have a clanking/rattling noise coming from the rear. Mostly from the right rear. It sounds like metal on metal, almost like something is bouncing around in the trunk. I thought maybe my jack was loose, but is was bolted down tight. I get the noise when the road is bumpy, especially at slow speeds. I don't have any problems on the FWY or at high speeds.
I've heard of aftermarket LCA's being noisy, but do the sounds I'm describing sound normal?
Thanks.
Old Jun 12, 2007 | 04:20 AM
rocket88's Avatar
I'd say either your adjustable panhard bar came loose, happened to me, or your muffler is on that side is making contact with the frame.
Old Jun 12, 2007 | 04:48 AM
AFChief's Avatar
I have the same thing since putting on my GMS LCA's. l get a thunk back there at low speeds. I think it's a combo of the urethyene bushings and the diff when it gets loaded and unloaded with the tranny at low speed.
Old Jun 12, 2007 | 11:54 AM
SteedaGus's Avatar
I had that issue on my own 06, it was the muffler for me too, but do check the panhard rod too make sure its tight.
Gus
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
