Springs and Struts and Sway Bars, Oh My!
Old May 8, 2007 | 11:45 AM
chrison600's Avatar
Hi all,
I'm going into research mode on some upgrades for the '06 GT Conv and need some help sifting through the options. From what I can gather, I basically have four options for suspension mods: Ford Performance, Steeda, Roush, and Saleen. Trouble is, I don't know which option is more respected, better performing, etc.
Does anyone know who builds the Ford Perf equipment? I thought I had seen at one time that it's Steeda stuff. Exactly the same Steeda equip that's available aftermarket? I'm kind of intrigued by the Steeda Ultralight springs. Are they the same as the Ford Perf springs?
The Roush stuff is a bit confusing. They have lowering springs as well as a "standard" option, but they recommend not using their standard springs on a lowered car. Does that mean the standard spring doesn't lower the car? They include the standard spring as a component in their suspension kit. I just don't believe that the kit doesn't lower the car at all.
The Saleen kit is priced very well. $800 for springs, struts, shocks, and a front sway bar. But it looks to use the stock strut caps, which are supposedly junk. Anyone have any feedback on the Saleen stuff?
Anyway, just wanting to try and make the best decision I can on suspension stuff. I started with the intention of just doing springs, but I will at least also do struts and upgrade the strut caps/bearings, because changing out strut springs is such a pain. I wouldn't want to do it twice if I can arrange not to.
Thanks for your feedback!
Chris
Old May 8, 2007 | 12:05 PM
kevinb120's Avatar
If you're not going to the track, the FRPP setup is hard to beat. You can just do the springs/damper kit and add the other stuff later so you don't have to pull it apart again. If you look hard in the for sale forum there are a few sets of the dampers in there for under 300, and you can pick up the springs cheaply. Getting the re-valved struts for <3-400 more is probably the least expensive way to 'properly' lower the car.
You can even do those dampers and the Steeda ultralites. From what I have seen, the ultralites provide a slightly softer ride.
Old May 8, 2007 | 12:08 PM
Chris, I know who'll be driving the car everyday. Get the Ultralites, she'll appreciate it.
Old May 8, 2007 | 12:29 PM
kevinb120's Avatar
I think I just talked myself into a decision
I'm not to worried about the caps myself, seems like a lot of $$, and the ultralites are not that extreme a drop. Most complaints seem to come from the Eibach pros or lower. And with new struts you're opperating in the proper range of travel for them.
Old May 8, 2007 | 12:34 PM
chrison600's Avatar
What about BMR? They have springs but no struts. NinoSport sells them and Eibach. For that matter, what about Eibach?
Chris
Old May 8, 2007 | 12:43 PM
kevinb120's Avatar
Eibach springs are the FRPP springs unless you get their more extreme stuff. You can get more sophisticated adjustable shocks, but most people don't need it. I'd say FRPP dampers/Steeda Ultralites. Bilstein just came out with a set of non-adj dampers but I don't know what the prices/details are.
Old May 8, 2007 | 08:54 PM
MooStang05gt's Avatar
You didn't mention what price range you were shooting for with this upgrade...
The FRPP Stg. 3 kit is hard to beat for $1100.. the springs lower the car about 1.5", dampers/shocks and front & rear sway bars.. I would think the sway bars would be a real plus... that's a lot of suspension for the price.
I have FRPP struts/shocks ($381) with a Ground Control Coil-over Conversion Kit with Eibach Sports Springs ($433) for a total of ($814 shipped) for the parts. I'm sure I would be using the FRPP Stg 3 set up if it had been on the market when I did my mods.
I would recommend a good set of LCA's, LCA relocation bracket, an adj. UCA and an adj. Panhard Bar ($553 shipped). I'm very happy with my BMR parts.
Bobby M.
Old May 8, 2007 | 09:03 PM
chrison600's Avatar
I think I've fallen in love with H&R. Their stuff is a little pricey, but oh so nice.
Link
Chris
Old May 8, 2007 | 09:23 PM
RandyB's Avatar
Thumbs up
Link
Chris
Another vote for the H&R springs here. I'm in the process of installing Bilstein shocks and struts right now as well - can't wait.
Old May 8, 2007 | 09:43 PM
chrison600's Avatar
So you did H&R springs with Bilsteins? Did you consider the H&R coil overs? I have Bilsteins on my truck. Seem to be good.
Chris
Old May 8, 2007 | 09:58 PM
GRAYPNY's Avatar
Personally I would go with the Roush suspension, but hey that's just me!
Old May 8, 2007 | 11:32 PM
classj's Avatar
H&R sport springs and Bilsteins all the way. I have had them on for a month and they have been great.
Old May 9, 2007 | 04:23 AM
RandyB's Avatar
Chris
No coil overs. I just did their sport springs.
Old May 9, 2007 | 06:29 AM
05YellowGT's Avatar
I've got the Steeda springs , struts & shocks and heavy duty upper strut mounts. I feel it's a good combination and I would recommend them ...
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
