Springs question.
Old Sep 14, 2008 | 11:22 AM
seabiscuit's Avatar
Springs question.
Is there any aftermarket springs set that improve handling but not lowering the car?
Old Sep 15, 2008 | 07:35 AM
rony1976's Avatar
Saleen and FRPP have minimal drops (1/2" or so) and they improve handling...
I'm not sure about Steeda, I can't remember if they do or don't. The other questions you have to ask yourself is how far are you going to push the car? Far enough that you might need a drop, or far enough where you shouldn't be spending any money 'cause the stock suspension gives you what you need?
Old Sep 15, 2008 | 07:40 AM
MaverickMLFD371's Avatar
Steeda have a very minimal drop in the front, while getting rid of that rear wheel gap in the rear.
The FRPP drop the car more than an inch and a half!
Old Sep 15, 2008 | 07:51 AM
highvolts's Avatar
I agree with Maverick, FRPP K Springs are very much more than half of an inch. More like an inch and a half...
Old Sep 15, 2008 | 09:48 AM
rony1976's Avatar
I haven't seen FRPPs drop compared to the Eibach Pro drop. I didn't think they were the same.
Are you guys sure?
Old Sep 15, 2008 | 09:56 AM
frdtch05gt's Avatar
Yes, the FRPP's drop the car down 1.5 inches, it's very noticeable. If I lower my car I will probably go with Steeda Sport springs, they lower about 3/4 inch or so.
Old Sep 15, 2008 | 11:53 AM
seabiscuit's Avatar
Ok so Steeda or Saleen is the less ones. I am looking the high once because of 4 reasons
1. I want improve handling.
2. I have got +24mm offset Razors with a new GT500 spec +2 so they are really +22 offset and the tire going out about 1/3 of inch out the car body line.
3. The worse gap is on the back but I am considering new tires on back 20R/35 what will increase sidewall by about 0,9 inch compering to stock setup
4. Here where I live it is rather recommended to have higher then lowered cars. The present stock setup is perfect for road conditions I meet everyday.
Old Sep 16, 2008 | 05:34 AM
here seabiscuit, maybe this pic will help. my car, razors 20s" with 24MM offset, steeda sport springs. no bottoming out of the front end what so ever in some parts of jersey here for me. overall great handling especially with tokico d specs
Old Sep 16, 2008 | 05:53 AM
maybe its sway bars your looking for more than springs if you don't want to lower it but improve handling????
Old Sep 16, 2008 | 09:55 AM
rony1976's Avatar
Good point... maybe you don't want to drop it but beef up the sway bars.
Also, why do you want better handling? Road events? If so, sway bars might help you more than springs according to what I've read in this forum from the road guys
Old Sep 16, 2008 | 03:39 PM
seabiscuit's Avatar
All the changes are connected with hopefully coming Saleen blower next spring. Here in Europe we do not have a lot of straight roads but a lot of cornering I need then good handling.
I am planning sway bar improvement as well hmm …. what can I get if I leave stock springs and put Tokico D spec? have that set any sense? will they fits stock springs?
MaverickMLFD371
What is your tire size? 275/30?
Old Sep 17, 2008 | 06:15 AM
yep the tokico will work with the stock springs. What tires are you running? Add more beef there as well for better handling
Old Sep 17, 2008 | 08:16 AM
Originally Posted by seabiscuit
MaverickMLFD371
265/35/20's Nitto555 Tires
Old Sep 17, 2008 | 09:37 AM
rony1976's Avatar
285-305s would help you...
D-specs will make the ride either softer or stiffer, the combination of the lowering springs is what would improve your handling during cornering. I don't think the shocks/struts by themselves would do much for your handling... Your thoughts people?
If you don't want something radical, buy the Saleen suspension setup, available for $599-$799 (you have to look around). It's a good compromise between drop and increased handling.
Old Sep 17, 2008 | 05:32 PM
Cavero's Avatar
Shocks/struts only dampen the motion of de/compressing the springs. Stiffer shocks are only going to keep the springs from changing length quickly, or dampen the reaction time. If you hit a bump or make a sudden turn the spring can't move as much in the same amount of time and it'll feel like a stiffer suspension. But in a steady-state corner like a sweeping bend it wouldn't really affect body roll because the spring is given plenty of time to reach its equilibrium. Right now your dampers are matched to your current spring rate and thats really how you should keep it. I'd get the swaybars unless you plan to get both springs and dampers. I saw a big difference with just those before I installed the springs.
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
