Spring Rates
Old Dec 3, 2005 | 02:37 PM
GTRacerX's Avatar
Anyone have the spring rates for Eibach Pro Kit &
Ford Racing Springs M-5300-K ?
Ford factory spring rates are:
Hardtop - 165lb front 142lb rear.
Convertible - 144lb front, 122lb rear.
Steeda Spring Rates:
Steeda Sport Springs - Spring rate is 200lb front, 175lb rear.
Steeda Ultralite Sport Springs - 195lb front, 175lb rear.
Steeda Street/Comp Springs - 225lb front, 185lb rear.
Old Dec 5, 2005 | 09:01 PM
softbatch's Avatar
I talk to cones.
Thank God the fronts are a coil over shock otherwise we'd be rolling around like pigs in mud with that spring rate.
Old Feb 6, 2006 | 11:03 AM
Redfire 05Gt's Avatar
<div class='quotetop'>QUOTE(GTRacerX @ December 3, 2005, 1:40 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I called Eibach tech support the other day and obtained the following:
Eibach Pro Kit:
Front: 171-230lb Progressive
Rear: 110-200lb Progressive
I also asked Jason at BMR about their new 1.5"/1.75" kit:
BMR SP009:
Front: 120-165lb Progressive
Rear: 130lb
Old Feb 6, 2006 | 11:32 AM
<div class='quotetop'>QUOTE(GTRacerX @ December 3, 2005, 3:40 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Difference of only 5 pounds up front and none in the rear?
If the Ultralites' are marketed for having 'the best ride quality', then the BMR's must feel like jelly and the Eibach's are like ultra-stiff! Both of which I know are untrue.
These spring rate numbers make no sense to me. [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
Old Feb 6, 2006 | 01:15 PM
I agree the spring rates are a little confusing, especially when trying to compare fixed with progressive. My understanding on the Ultralites is that they're lighter in weight and thus the ride is better as it reduces unsprung weight.
06TUNGVERTGT installed BMR's SP010 1.5"/2" progressive springs and he said:
<div class='quotetop'>QUOTE</div><div class='quotemain'>It is much firmer, but not harsh, I may still do the Tokico struts soon, I would try it first and see what you think, before investing in the struts[/b][/quote]See thread: showtopic=43641
I am inquring as to the spring rates for SP010...[edit] They're the same.
Old Feb 6, 2006 | 01:39 PM
softbatch's Avatar
I talk to cones.
[/b][/quote]
GTracerX
Where did you get your stock spring rates
Taken from a spec manual for the 2005 Mustang
Front
Spring rate N/mm (lb./in.)
GT Coupe: 23.9 N/mm (136.5 lb/in). All others: 20.0 N/mm (114.2 lb/in).
Rear
Convertible: 21.5 N/mm (122.8 lb/in). Coupe: 24.9 N/mm (142.2 lb/in)
Old Feb 7, 2006 | 08:19 AM
<div class='quotetop'>QUOTE(Redfire 05Gt @ February 6, 2006, 12:18 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
SP010 has the same rates as SP009:
Front 120-165 Progressive
Rear 130 Fixed
Old Feb 8, 2006 | 09:26 PM
RadBOSS's Avatar
Make sure you are not confusing spring rates with wheel rates
Old Feb 8, 2006 | 09:41 PM
don_w's Avatar
<div class='quotetop'>QUOTE(softbatch @ February 6, 2006, 12:42 PM) Quoted post</div><div class='quotemain'>
GTracerX
Front
Rear
[/b][/quote]
Link to Spec Manual (pdf file)
Old Feb 8, 2006 | 10:54 PM
From http://www.2005stang.com/gallery/albums/us...stang_specs.pdf (Thanks Don)
SPRING rates:
Front
GT 136.5
Others 114.2
Rear
Coupe 142.2
Convertible 122.8
The WHEEL rates are:
Front
GT 170.7
Others 148.5
Rear
Coupe 170.7
Convertible 145.6
A GT Coupe has a Front AND Rear Wheel Rate of 170.7...
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
