spark plugs and carbon build up
Old May 14, 2008 | 05:43 PM
1550GT's Avatar
Is there a product that can be used in the combustion chamber that will reduce the amount of carbon build up, and if so will it work on the carbon that is already built up. I have an 06 with 26000 miles on it and am just reading about the problems with the two piece spark plugs and the carbon build up.
For those that have changed out the plugs, what did you reinstall?
Old May 14, 2008 | 07:13 PM
cdawg's Avatar
I put the Champion one piece plugs in. So far, couldn't be happier. But only a couple hundred miles on them at this point.
Can't answer your question on reducing the carbon build up. I know that taking your car out on the highway for some miles is said to get rid of some of the carbon.
Old May 14, 2008 | 07:54 PM
highvolts's Avatar
I can't speak for anything to prevent the build up w/o taking the plugs out. However, quite a few people (including me) have taken the plugs out, clean & nickel anti-seized them and then reinstalled the stock plugs. The anti-seize will prevent the build up of carbon and allow you to remove the plugs easily next time.
See this thread (Its when I did it to mine):
http://forums.bradbarnett.net/showthread.php?t=466613
Be Careful & Follow the TSB, & Don't use a lot of force to take them out.
-Jason
Old May 14, 2008 | 08:25 PM
429 Boss Mustang's Avatar
hmm i heard some pretty good stuff about this sea foam it might help bro
http://www.seafoamsales.com/motorTuneUpTechGas.htm
CoyotePremium13
Oct 7, 2015 07:17 PM
RoushRS3
Sep 29, 2015 08:03 PM
GLOCKer
Sep 28, 2015 05:20 PM
