Some Cold Air From Roush
I must have been good this year. I mentioned a Roush CAI a while back but it wasn't on my Christmas list. My wife surprised me. She ordered it from the good folks at Stillen.
This is a quality kit with a well respected name. The plastic is thick and sturdy. It's every bit as solid as the factory airbox. Nothing flimsy here. I really love the look, the fit, and the finish. It uses the stock MAF. Although, no tune is required, i had always planned to get a CAI+tuner. I still do.
A torx bit was included in the kit. It was supposed to be used for either the stock MAF or for the screws that connect the shield to the tube. I'm not sure which because it fit neither one. The bit was the wrong size. You may need your own assortment of torx bits. It took me about 30 minutes to install.
At WOT i feel a little bit extra that wasn't there before. Also, the tone of the exhaust at WOT is a bit deeper. I believe those two things are what you can expect from a tuneless CAI on these cars. My tuner will add nicely to this.
If you are looking for great plastic CAI, don't worry about this decision, the Roush/Airaid CAI is a great choice.
yes it does. same exact intake as airaid. probaby manufactured at the same airiad factory. only difference i think is the roush name painted on the tube.
Thier supercharger does not come with a tuner/loader either. They have you overnight the ECM to them and they flash it. They do this so that they don't get into legal issues and keep Ford happy. Also, they can look at the ECM and if you have had it to a tuner they can void your warrenty. I was considering Roush but I don't like the way they *****foot around with the warrenty issues. If I ever supercharge my car I will do it with someone else.
If you want to stick a supercharger onto an other wise stock car and don't plan on modding or getting a custom tune, Roush is fine. You start modding/tuning, the Roush warranty will be voided.
I don't see this is poossee-footing - they give you a warranty, so they don't want a 1/2 azz tune blowing the motor.
I don't know if any other co provides the warranty that Roush does - though I that there are options to buy warranties with some blowers.
Neil - that kit looks quality. I have the JLTII CAI right now and am happy with it except when I tried to add the shield it caused the airfilter to rub against the underside of the hood - so I removed it. I may try and trim it down a bit for a better fit. I would like to see what kind of gains the Roush CAI and BamaChips tune would result in though.
I agree with everything you've stated except for this.. Also, they can look at the ECM and if you have had it to a tuner they can void your warrenty. This is not true and has been re-hashed over and over again and the fact is ? Ford cannot void the factory warranty unless it's proven that the aftermarket part or re-flash was directly responsible for causing the warranted parts in question to fail and that's the bottom line..
Let's say you flash your PCM with a 9000 RPM revlimiter or run an incorrect MAF transfer function and burn out your cats, cylinders, etc... You reflash it back to stock and take it to the dealership with a
attitude. An aftermarket supercharger will also void the factory warranty.
and if your curious as to how I found about this ?? upon doing some extensive research, I spoke with 2 of Ford's feild service engineers who both confirmed Ford's warranty policy...So there you have it in a nutshell..
With the Roush supercharger, Roush takes over the warranty from Ford. If you keep the SC the way Roush delivered it, any problems are covered. Change anything and it becomes your supercharger and not Roush's. Any problems are on your dime, which is only right IMHO.
Getting back to the Roush CAI..... can you provide some more details in terms of performance gain? I keep looking at these kits and have been leaning towards a CnL racer or KN type kit or maybe this roush.
without the tune, do you think it would be worthwhile install?
Sam
Sam
Sam
Sam
Airaid says it gives a 17HP gain. I haven't verified it on a dyno. Therefore I can't give you any numbers. I'll have to take Airaid's word for it. Whatever it is, it's better than the stock airbox. At WOT and at higher rpms, i feel a little extra power. That's probably not what you are looking for but that's the truth of the matter.
To answer your question...without the tune would it be a worthwhile install?--it's hard to say, IMO most people will not be satified. If you are expecting better throttle response, you won't get it. If you expecting more power power on takeoff, you won't get it. You will feel more power at WOT and at high rpm. Because that it where you realize that your intake is a bit more efficient.
I decided to use this intake for these reasons:
(1) It looks better than the stock airbox
(2) It performs better than the stock airbox
(3) I don't want to dissassemble anything ever. If I go in for service, i will reflash it back to stock and leave the roush intake on. When I sell the car or trade it in, the roush intake will more than likely stay on the car. I had my "own" CAI on a previous car and it broke down one day on the highway. I had to change out the airbox on the highway before calling the tow truck to take to the dealer. It turned out to be something unrelated to the intake but I don't want to have to do that again.
(4) When I use this intake with a tuner, I believe it will perform as well as the others.
