SOHC vs OHV
Old Aug 6, 2006 | 02:15 PM
mwax321's Avatar
SOHC vs OHV
I just had a question for those of you that know a lot more about car engines than I do:
What made Ford decide to use SOHC for the 4.0 V6, and OHV for the 4.6 V8, and what makes the OHV design better for the 4.6 V8 engine? Is it a perfomance increase, or is it more about reliability?
Old Aug 6, 2006 | 02:18 PM
Fazm's Avatar
the 4.6 is a SOHC design, not a OHV (pushrod) design.
Old Aug 6, 2006 | 03:18 PM
mwax321's Avatar
Hrm according to Ford.com its an OHV, maybe i misread
Old Aug 6, 2006 | 03:44 PM
sound wave's Avatar
i think the last mustang engines to use the ohv design were the last generation v-6 3.8's.
Old Aug 6, 2006 | 03:51 PM
mwax321's Avatar
Okay I think its a mistake on the Ford website then.
http://www.fordvehicles.com/cars/mus...eatures/specs/
If you read it there it says OHV
BUT
If you read this
http://www.fordvehicles.com/asp/popu...nPopupID=10642
Says SOHC
Or maybe there's something I just don't understand.
Old Aug 6, 2006 | 04:24 PM
The Boss Hog's Avatar
BUT
If you read this
Says SOHC
Every modern engine has been an OHV (OverHead Valve) since the Rambler 6's of the mid 60's. It originally just meant the valves were above (over) the pistons instead of beside the pistons as in the old flathead engines.
Now adays OHV is used to designate engines with have the cam low in the block and use push rods and rocker arms to open the valves. SOHC (Single OverHead Cam) is used to designate an engine that places its cam in the head above the valves. SOHC means one cam above each bank and DOHC means two cams for each bank.
Hope that helped.
The Boss Hog
Old Aug 6, 2006 | 06:50 PM
Bingo's Avatar
^^ What he said. OHC = cams above valves, OHV = cam in block.
Old Aug 6, 2006 | 06:56 PM
AnotherMustangMan's Avatar
Cam Tease
Not quite, OHV = Everything.
Old Aug 7, 2006 | 01:48 PM
mwax321's Avatar
Yes i understand what overhead valve means, but if what you are saying is true, why would they say the V6 is SOHC and then write the GT as 4.6 OHV. I mean you may as well go and say SOHC for both. So maybe it is a typo
Old Aug 7, 2006 | 07:56 PM
Fazm's Avatar
it is a typo. Yes everything technically has the valves over the head, but OHV is strictly used to describe pushrod motors nowadays.
Boomer
Jan 21, 2008 09:16 AM
Evil_Capri
May 25, 2007 06:24 PM
427sohc
Jul 6, 2006 06:55 PM
Scothew
Aug 4, 2005 10:21 PM
maddhatteroo7
Dec 19, 2004 02:21 PM
