So close I want to cry
9 is not my lucky number.
60' = 1.765
330' = 5.349
1/8 = 8.325
MPH = 83.09
1000' = 10.869
1/4 = 13.033
MPH = 104.31
ARRRRRRGGGGGGGHHHHHHHHH That's it I'm getting an H-pipe, probably the pypes one.
Launched at 5000 and I advanced the following adjustments to my tune:
global spark: +1
spark 2k-4k: +.5%
spark 4k-6k: +.5%
The spark adjustments helped a lot
330' = 5.349
1/8 = 8.325
MPH = 83.09
1000' = 10.869
1/4 = 13.033
MPH = 104.31
global spark: +1
spark 2k-4k: +.5%
spark 4k-6k: +.5%
<div class='quotetop'>QUOTE(dustindu4 @ April 29, 2006, 5:58 PM) Quoted post</div><div class='quotemain'>
1/4 = 13.033
[/b][/quote]
Ah, what's thirty three one thousandths among friends?
I'll bet if your car were Grabber [img]style_emoticons/<#EMO_DIR#>/yes.gif[/img] range it would have broken into the 12's.
You'da had mo' juice!
1/4 = 13.033
[/b][/quote]
how are u not running alot faster than that with all ur mods?
if im lookin correctly: K&N, 93 Tune, swaybar delete, tri-ax, LCA, 4.10's, Micket Thompsons, water pump and UDP????
thats a good amount of mods, i think u should be alot faster than where you are at
no offense, just a thought
-mike
-mike
<div class='quotetop'>QUOTE(dustindu4 @ April 29, 2006, 5:09 PM) Quoted post</div><div class='quotemain'>
My stock H pipe is choking me, I need better exhaust flow. I'm putting an O/R pipe in Thursday or Friday
[/b][/quote]
why is your trap so low??? stock stangs trap that high. i understand you had a really good launch (bravo btw), but you should be trappin 3mph higher with those mods, and runnin 12.80s with that 60'
[/b][/quote]
Originally Posted by stang9325
Yeah, with your mods there is something definately wrong. With less mods than you I have run a best of 13.06 @ 107 on stock tires and gears. That was with a 1.998 60ft too.
