slp loudmouth install problem
Old Sep 4, 2007 | 09:08 PM
Clark Kent's Avatar
I just installed my loudmouths which I picked up for 100 bucks by the way, and the install went preety well except for the fact that the stock clamps that hold the chrome tips to the pypes were too big, and did not fit
Old Sep 4, 2007 | 09:22 PM
mister's Avatar
When I installed my Loudmouths, it came with all the correct clamps in the kit. You could contact SLP and have them send you the right ones....
Old Sep 4, 2007 | 09:46 PM
Clark Kent's Avatar
o so there are suppose to be clamps from slp. i bought this used and the guy told me he used the stock clamps. Would i be able to just buy some clamps from a auto store and juts fit those also would be safe to drive without them for now
Old Sep 5, 2007 | 06:39 AM
MaverickMLFD371's Avatar
actually the stock clamps should work, they are the same size as the clamps provided from SLP.
Old Sep 5, 2007 | 01:36 PM
Rays197's Avatar
yes, there were 4 clamps that came with my kit. if you do buy some clamps make sure they are stainless and not galvinized.
Old Sep 5, 2007 | 02:53 PM
Clark Kent's Avatar
no the stock clamps i have are alomst 10in in diameter but the slp pipes are 8in
Old Oct 3, 2007 | 07:04 PM
Eatmydust's Avatar
I've had my slps for about a year now, and all of a sudden the right one is hanging an inch and a half lower, underneath the car everything looks fine, it seems the welds are holding but the right one is still droooping. I dont know what to do.
However, when i installed them i never sawed off the line up pins from the stock h pipe ends which inhibited the slps from fitting the tube all the way, could this be the problem!!!????
-Dan
Old Oct 3, 2007 | 07:12 PM
Eatmydust's Avatar
I also forgot to add that the left side is really solid when you push on the tip it doesnt move...the right side however when you push it it goes down, its almost like its loose, but i checked all the bolts and no problem all are tightened....hmmm
Old Oct 3, 2007 | 07:25 PM
Eatmydust's Avatar
Nevermind, the weld failed on the first hanger im really dissapointed
Old Oct 3, 2007 | 07:35 PM
frdtch05gt's Avatar
SLP is garbage, don't even bother with them. I got the FRPP GTA's and I'm very happy with them.
Chip
May 10, 2018 12:57 PM
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
TonyJestis
Aug 21, 2015 06:06 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
