Which Short throw shifter?
Old Nov 21, 2006 | 12:35 PM
  #141
Centurion96's Avatar
So does anyone have photos of the Pro 5 installed at the lower position? Pix please.
Does the Steeda also have a lower mounting position?
TIA
BB
Semper Fi
Old Nov 21, 2006 | 01:06 PM
  #142
Stoenr's Avatar
And how invloved is switching from lower to higher once installed?
Old Nov 21, 2006 | 02:57 PM
  #143
tom281's Avatar
TIA
BB
Semper Fi
See post #43, pic #6. That's the Roush **** in the lower position.
See post #43, pic #4. Lift the shift boot, remove the 2 bolts on the side of the shift lever, raise/lower shift lever, reinstall bolts. Very easy, 2 minute job.
Old Nov 22, 2006 | 08:54 AM
  #144
touring's Avatar
TIA
BB
Semper Fi
Yes the steeda does have a lower mountting position,i just had the tri ax installed and i love it!! cant belive that wasent my first mod!!i'll take pics if you want
Old Nov 22, 2006 | 11:34 AM
  #145
Please and thanks, it will give me a comparison between it and the Pro 5 photo from tom281. I'm also considering the GTA axle backs from ninosports.
Thanks all.
BB
Old Nov 22, 2006 | 07:21 PM
  #146
SoFlaBoss's Avatar
Pro 5.0 from LFP will accept stock shifter ****
Originally Posted by SoFL05GT
I talked to Mike (possibly Mark) at LFP, who contacted Pro 5.0. Bottom line is Pro 5.0 says that Ford changed the thread size at some point and Pro 5.0 didn't keep up. Instead Pro 5.0 answer was to include their own shift **** (little round black ****), that fits their shifter. So, I reached a dead end. I sent an email to SteedaGus, asking for help. I think the shift lever that Steeda supplys with their Tri-ax will work. I hope so!
Meanwhile, anyone considering to purchase a Pro 5.0 shifter should make sure the shifter will accept the stock ****, which to my knowledge is thread size Metric 12 X 1.75. The Pro 5.0 shifter from LFP does not.
Gus at Steeda has been very helpful. What I know now, is that although the Pro 5.0 from LFP does not have the same thread size/pitch as the stock shifter, however, the stock shifter **** will still fit the Pro 5.0 because the stock shifter **** only has a nylon insert, which was originally unthreaded, until it got screwed onto the stock shifter. The nylon insert adapts to the Pro 5.0, which is why the extra effort is needed to screw it on the Pro 5.0. However, my new Roush billet shifter **** still won't fit. So, I am temporarily using the stock shifter **** until I can find a replacement shifter lever that fits both the Pro 5.0 and the Roush shifter ****. Again, the Pro 5.0 shifter from LFP does not have the same thread size as the stock shifter.
Old Nov 23, 2006 | 07:06 AM
  #147
BuzzyStang05's Avatar
Ditto. On my Pro5.0, I just cranked the stock **** on there with a little extra effort to rethread the nylon. It's on there solid.
Old Nov 24, 2006 | 10:49 PM
  #148
DokterD's Avatar
Hurst
I put the Hurst in about a month after buying my 07 GT. At first a little stiff but now, no problems. Notchiness is gone and I can shift all gears with the gas floored with NO missed gears. Spend as much as you like but I'm more than satisfied with Hurst. My only complaint is that the T-handle (polished aluminum) gets friggin' cold in the winter. BTW, the T made all the difference to me. 162.00 and it shifts great. You do need to blue locktite the handle tho', it will vibrate loose after a while if you don't.
Old Nov 25, 2006 | 03:24 AM
  #149
Poco's Avatar
When I first installed my B&M short throw I was really happy but now it squeaks from time to time.I had to squirt a little grease on the fastners to calm it down.I did install the bushings correctly and would just like to get a Hurst instead.
Old Nov 25, 2006 | 02:28 PM
  #150
GPStang06's Avatar
I have been away and haven't had time to post all my stuff from my install but here is some of the pictures of the shift **** and throw from the Steeda Tri-Ax.
1st and 2nd, **** height: Stock Shifter:
1st to 2nd throw, lower height: Steeda Tri-Ax.
Upper and Lower position comparison: Steeda Tri-Ax
I have mine set back to the lower on the Tri-Ax, it is basically the same as the stock shifter height.
Old Nov 25, 2006 | 02:36 PM
  #151
Stoenr's Avatar
How the heck did you manage to get the 2nd 2 pics look like you have 2 shifters lol
The 1st one I can see the cut n paste job, nice job on the 2nd 2.
And thanks gives a great visual!!!
Old Nov 25, 2006 | 02:42 PM
  #152
GPStang06's Avatar
LOL all Photoshop, the master I am not . The first picture had the flash on for the one pic but not the other, thats why the lighting is different.
Old Nov 25, 2006 | 04:05 PM
  #153
tom281's Avatar
Great pix Gary!
Old Nov 26, 2006 | 06:26 AM
  #154
Hatchman's Avatar
Nice chops, that really makes it easy to see!
For comparison, here's the Hurst 1-2 shift. Looks a little shorter than the Steeda, but it also locks you out of 3rd on WOT shifts and is pretty notchy, so I wouldn't recommend it.
Old Nov 26, 2006 | 08:11 PM
  #155
65sohc's Avatar
Dang! The throw isn't even the distance of the shifter ****! That must be a huge change in leverage. Hurst must have really designed it to be used with their longer handles.
Old Nov 27, 2006 | 05:47 AM
  #156
Hatchman's Avatar
They did, it's really designed to be used with the longer chrome handle, where the throw would be a little longer. The effort to shift is a little higher than stock, and a little notchy, but I like the short throw, you barelly have to flick your wrist. I'm installing a CHE K member brace with torque limiters to stiffen up the front end and cure the 3rd gear lockout under WOT shifts.
Old Nov 28, 2006 | 08:51 PM
  #157
touring's Avatar
guys
the steeda tri ax shifter is the way to go it's perfect in every shift and it's only getting better. If i had to do it over again this would have been my first mod
Old Nov 28, 2006 | 09:36 PM
  #158
GPStang06's Avatar
Have to agree. I have close to 1000 miles on it now and it's to the point that I can shift with just a finger and my wrist. Really broke in nice.
Old Dec 5, 2006 | 06:04 AM
  #159
metroplex's Avatar
Nice comparison! It looks like the Tri-Ax allows for a much shorter throw in the odd numbered gears while the even gears have the same amount of throw from what I could see.
Old Dec 5, 2006 | 07:11 AM
  #160
GPStang06's Avatar
I have gotten all the pics off the camera and am close to doing a writeup of my install. I'll post when ready.
Something I did also was flip the shifter arm around. In my pictures above the odd gears (1st and 3rd) set the arm and **** a little further back from what they are as stock. I flipped that piece around so the angle is facing the AC controls and now the 1st and 3rd are in the same place as stock but 2nd and 4th are a little more forward. I'll snap some pics and maybe do another video clip of how easy the shifter is now that it is broke in.
