Shock Recommendations
Better than Bilstein? Are Bilsteins available for the '05/'06 Mustang yet? I'm fairly certain the Roush cars use them but I haven't seen any part numbers released yet. I plan to go with them.
If you want to use the stock springs then the Tokicos are your only choice that I know of right now.
What you can do is get some Koni or Bilsteins and make the fronts into a ride height adjustable coil overs and use a smaller diameter springs which may give you more clearance for some wider wheels and tires.
Meet Krissy, Our Star Racer
Originally posted by Motomez@December 8, 2005, 11:00 PM
What do you recommend for shocks/ Struts?. On past cars I have run Koni's or Bilstiens. I think that there may be better options.
Sorry to state the obvious...
http://forums.bradbarnett.net/index.php?sh...40022&hl=shocks
http://forums.bradbarnett.net/index.php?sh...39798&hl=shocks
http://forums.bradbarnett.net/index.php?sh...38947&hl=shocks
