Setting Camber with Steeda Heavy Duty Upper Strut Mounts
Old 9/4/12, 05:31 AM
66COUP's Avatar
The Steeda logo should be closest to the tire with the triangle points pointing toward the front/rear bumpers, right? The strut nut is at 46ftlb and bottomed out.
Old 9/4/12, 08:58 AM
randy_tho's Avatar
That sounds right. Do you have any other suspension modifications?
http://www.steeda.com/store/uploads/...-mounts--1.pdf
Old 9/5/12, 05:18 AM
66COUP's Avatar
This is all of the suspension stuff that I have installed at this time.
555-2003 - Steeda Stop The Hop Pak - Lowered Vehicles - 05-10
555-2551 - Steeda Adjustable Panhard Bar
555-2555 - Steeda Heavy Duty Panhard Bar Brace
555-1064 - Steeda Ultimate Swaybar Kit - Includes Billet Endlinks - 05-10
555-8206 - Steeda Ultra-Lite Springs, 1.25" Front, 1.5" Rear
555-8113 - Steeda Billet Front Swaybar Mounts
8750-1030 2 STR.T Strut
8250-1008 2 STR.T Shock
555-8120 Steeda heavy duty upper strut mounts
BTW, the strut tower brace and front sway bar endlinks are disconnected.
Old 9/8/12, 01:08 PM
66COUP's Avatar
I got it...the metal sleeve that slides over the strut was flipped. When I put the plates on, I took them straight out of the box and didn't pay attention to the diagram. I should not have assumed that they were assembled correctly in the box. I got one extra degree of camber too! Thanks for the help.
Old 9/8/12, 01:41 PM
randy_tho's Avatar
Glad you worked it out. It's been too long since I installed mine. Trying to remember what the sleeve is. Are you talking about the dust cap thing?
HizliBullet
GT350
14
11/14/15 08:59 AM
Mackitude
8/17/15 04:14 PM
SMBJoshy
8/16/15 02:48 PM
7/30/15 06:47 AM
killaz05
7/24/15 08:49 AM
Quick Reply: Setting Camber with Steeda Heavy Duty Upper Strut Mounts
