SCT2 Tuner Question?
Old Aug 5, 2007 | 06:06 PM
GRAYPNY's Avatar
When uploading the tune which does the car respond to. I have settings for 3:23 - 3:55 - 3:73 - 4:10 ratios and I have the ability to adjust the revolution per mile for the tire size.
I guess my question is if you set the RPM for tire size does that over-ride the gear ratio selection? Or is it even necessary to select the gear ratio when you set the RPM for the tire size?
Old Aug 5, 2007 | 06:34 PM
don_w's Avatar
To correct the speedometer, it needs to know both the gear ratio and the tire size.
Old Aug 5, 2007 | 07:41 PM
GRAYPNY's Avatar
Thanks Don
Bryanh24
Oct 14, 2015 08:43 AM
MustangConvert11
Sep 30, 2015 08:01 PM
