SCT TUNNER QUESTION
I HAVE THE USB CONNECTION AND THE SCT SOFTWARE.IT SEES THE SCANNER AND LISTS THE TUNES THAT ARE ON IT.SOMEONE MADE ME A TUNE FOR MY MOTOR ONLY. FROM BAMACHIPS.I DONT WANT TO SCREW IT UP, SO CAN ANYONE WALK ME THRU IT.DO I HAVE TO RETURN CAR TO STOCK LIKE THE PREDATOR I HAD OR IS THIS DIFERANT?
It seems that you have the Driver's downloaded as you say it recognizes your X-2 now. Open the Extreme Tuning software and then click on small box with 3 dots just to the right of the white opening. This will open your folders on your PC, select the location of the file you wish to upload to your X-2 and click on it. Once you have this goto " Program X-cal 2" and click on the button. There you will name the program in the X-2 and finally hit the upload button and it will place it in the location that you have selected. If you have a program already in that location then it will overwrite it so you may wish to select a file that's not working perfectly for you first unless you have back ups for the files you already have. If so then don't worry about it.
Thanks,Doug.
Thanks,Doug.
