SCT TUNNER QUESTION
Old Nov 6, 2005 | 06:19 PM
mikem's Avatar
I HAVE THE USB CONNECTION AND THE SCT SOFTWARE.IT SEES THE SCANNER AND LISTS THE TUNES THAT ARE ON IT.SOMEONE MADE ME A TUNE FOR MY MOTOR ONLY. FROM BAMACHIPS.I DONT WANT TO SCREW IT UP, SO CAN ANYONE WALK ME THRU IT.DO I HAVE TO RETURN CAR TO STOCK LIKE THE PREDATOR I HAD OR IS THIS DIFERANT?
Old Nov 6, 2005 | 06:43 PM
Doug@C&L's Avatar
It seems that you have the Driver's downloaded as you say it recognizes your X-2 now. Open the Extreme Tuning software and then click on small box with 3 dots just to the right of the white opening. This will open your folders on your PC, select the location of the file you wish to upload to your X-2 and click on it. Once you have this goto " Program X-cal 2" and click on the button. There you will name the program in the X-2 and finally hit the upload button and it will place it in the location that you have selected. If you have a program already in that location then it will overwrite it so you may wish to select a file that's not working perfectly for you first unless you have back ups for the files you already have. If so then don't worry about it.
Thanks,Doug.
Old Nov 7, 2005 | 02:56 PM
Firedude's Avatar
Doug's directions should work for you with no problems. If you get stuck you can give me a call today and I will walk you through it. 928-783-5386. Ask for Bret.
Old Nov 7, 2005 | 04:24 PM
Badandy's Avatar
Wow. Please get rid of the caps. It distracts people and makes it unpleasant to read. That's all the constructive criticism I have.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
