RUN 110 OCTANE?
Old Sep 16, 2005 | 11:01 AM
WERKED 66's Avatar
i am going to the track either today or in two weeks...now i am running the 93 performance tune from bamachips....would i benifit to put two or three gallons of 110octane into my tank that has 93 or would i just be wasting my money....
Old Sep 16, 2005 | 12:01 PM
packhater's Avatar
Where the heck are you getting 110 octane?? And how much is it?
Old Sep 16, 2005 | 12:48 PM
Tiberius1701's Avatar
You would be wasting your money. 93 octane will be all you need with your tune.
Old Sep 16, 2005 | 01:34 PM
RRRoamer's Avatar
110 race gas? You catalytic converters and O2 sensors (all 4 of them!) won't like it one bit. You might want to price a pair of cats and 4 sensors to see if you can afford the gas...
It probably won't damage the car right away, but over time the lead will build up on the sensor cells and the convert until they are not operational (enough) and you ECU pops a code...
Old Sep 16, 2005 | 01:54 PM
don_w's Avatar
Unless you somehow increased your compression ratio to about 14:1, you don't need (or want) 110 octane fuel.
Old Sep 16, 2005 | 02:46 PM
dustindu4's Avatar
9 is not my lucky number.
110 octane fuel is leaded, your car isn't configured to handle it
Old Sep 16, 2005 | 03:59 PM
WERKED 66's Avatar
ok guys it`s good to know stuff like this...thanks for the info...i dont want to mess my car up either ..
Old Sep 18, 2005 | 01:55 AM
TURBO 05's Avatar
you can still buy 100 - 104 octain unleaded $5.00/gallon
Old Sep 18, 2005 | 07:23 AM
Hatchman's Avatar
Not all race gas has lead in it. There are several speed shops that sell various levels of octane, with or without lead.
For example:
BP CSP is one of the highest octane, oxygenated unleaded fuels available. Spec Fuel for high compression, fuel-injected Toyota-Atlantic North America Series. Street legal in most states.
• Color: Yellow
• Oxygenated: Yes
• Research Octane: 108
But, it is a waste of money with a 93 octane tune.
Old Oct 2, 2005 | 02:11 PM
RRRoamer's Avatar
Hatchman,
That 108 Research grade gas is only about 103 in the "Real" world USA (aka: (Research + Motor) / 2 rating method that is used at the pump). Still good gas, but as good as "108" sounds when you compare it to your "normal" 93 pump gas.
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
