Ruby gets new racing shoes
Ruby just received her new racing tires from the TireRack. They are 18x9.5 Kazera KZ-A, Black, fitted with BFG 275/35R18 Drag Radials.
[attachmentid=11051]
I have not had a set of racing tires since 1970 when I had a set of Goodyear Bluestreaks on my '69 Road Runner. Any advice on how to break in these things, how much air to run and how to launch with them would be appreciated. Thanks
The Boss Hog
The Boss Hog
The Boss Hog
The Boss Hog
Well you are going to need to heat them up a bit
Thanks for the replies guys
I only got two for right now but I plan on getting matching ones to run on the street when I can afford it. When I do, it will be 18x8.5 with 255/45Z18 BFG KDW's on the front and 18x9.5 with 285/40Z18's in the rear.
I hope to get to the drag strip tomorrow. If I do, I will start out at 22 psi and go down 2 psi at a time until I either 1.) stop improving or 2.) break something
Either case, I'll let you know what happens.
The Boss Hog
Either case, I'll let you know what happens.The Boss Hog
The Boss Hog
The Boss Hog
How are you going to drive them in the rain down there in FL? You will be spinnin all over the place. Do not know correct air pressure but do know if its too low you will spin the wheels inside the tires. Been there Done that !
I like everyone else are waiting to see them on the pony. Did you put them all around or just the rear? ROLL ON
Originally posted by Mongoose@February 3, 2005, 8:43 PM
Those are some big ole fat donuts for sure. Ok where did you get um and the $$$
[attachmentid=11172]
But the small diameter will help the gear ratio at the strip.
I got them from the TireRack.com and the pair cost $860 mounted, balanced, lugs, and shipping.
The Boss Hog . . . . . . . . Rolling on
Originally posted by The Boss Hog+February 3, 2005, 7:01 PM--><div class='quotetop'>QUOTE(The Boss Hog @ February 3, 2005, 7:01 PM)</div><div class='quotemain'><!--QuoteBegin-Mongoose@February 3, 2005, 8:43 PM
[/b][/quote]OH my goodness that is a hit for sure. I am going over to tire rack and look around. Those tires sure do look short on the car. have you changed to the 4:10 or are you still stock?
I see you are Rolling On
AdPock
Oct 16, 2015 02:58 PM
those are sweet
Good luck at the track. Put a little heat in them.
