royal purple gear oil and ATF..good idea?
Old Nov 7, 2007 | 06:47 PM
YaoNYC's Avatar
hi all,
would it be very helpful if i did:
Royal purple 75w90 gear oil for differential
Royal purple max ATF for auto tranny
anyone feedback would be GREAT
thanks!
Old Nov 7, 2007 | 06:55 PM
metroplex's Avatar
Your automatic needs a Mercon-V ATF. Does max ATF meet/exceed Mercon-V? If so, go ahead and use it.
I would recommend a 75W-140 w/ friction modifier for the rear differential.
Old Nov 7, 2007 | 07:03 PM
blkstang06's Avatar
Originally Posted by YaoNYC
hi all,
thanks!
I run Royal Purple all the way Around! I also believe www.brenspeed.com recommends it!....I'm sure many are just as good but probable none any better!
Old Nov 7, 2007 | 08:31 PM
YaoNYC's Avatar
hi metroplex,
thanks always for your information.
i was thinking of just adding amsoil or ford racing friction modifier...but then then i ready royal purple gear oil has friction modifier already added to it.
which option is better? stock gear oil with added friction modifier or royal option?
Old Nov 8, 2007 | 06:26 PM
metroplex's Avatar
Ford/Motorcraft gear oil is overpriced. I would add 4 oz of Ford friction modifier with whatever gear oil you use. I never trust the formulations.
Old Nov 9, 2007 | 08:21 AM
YaoNYC's Avatar
thanks metro.
exactly which model # ford racing friction modifier should i get? there are 2 or 3 of them.
thanks!
Old Nov 9, 2007 | 01:14 PM
metroplex's Avatar
Motorcraft XL-3, available almost anywhere. There's only 1 part #.
http://www.fcsdchemicalsandlubricant...nsaxle%20Fluid
Old Nov 9, 2007 | 06:12 PM
06GT4RAD's Avatar
Not a fan of RP.
My choice is Redline.
Richard
Rando
Aug 25, 2021 11:12 AM
NC14GT
Sep 27, 2015 05:35 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
