Roush Rear Springs Installed
Old Feb 18, 2006 | 12:11 PM
GRAYPNY's Avatar
I put the rear springs in yesterday and it dropped the rear approximately 1 inch. It looks like the rear is still centered so I don't really need to install the BMR adj. panhard rod. Is there any benefit to installing it since I already have it? Here's a quick picture after the install and another one before for a comparison. The picture on the left is with the Roush springs. Ride is a little bumpier but not bad and I think it leveled the car out nicely.
Old Feb 19, 2006 | 11:05 AM
GRAYPNY's Avatar
and if anyone cares I used a plumbob and tape measure today and the left side is .25 inch futher from center than the right side.
Old Feb 19, 2006 | 07:15 PM
Mustang69-05's Avatar
I think it looks alot better with the new springs. I've been thinking about this for a while. Did you check your rearend before you started to see if it was straight? I've heard some have been off from the get go. If you've got the panhard bar might as well put it in and adjust it. Nice ride by the way! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Feb 19, 2006 | 07:53 PM
Stoenr's Avatar
Nice isnt it! The ride is not bad at all. Makes for less bounce on the hard shifts too, and transfering some weight to the rear wheels slightly faster.
I took measurements and the rear is 1/4 higher than the front now. Perfect imo. Rear wheel gap gone too!
You wont even notice the slightly bumpier ride after driving a few weeks.
Top picture is lowered in the rear with the roush springs
Old Feb 19, 2006 | 08:15 PM
<div class='quotetop'>QUOTE(GRAYPNY @ February 18, 2006, 1:14 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Looks great, Rich! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Feb 19, 2006 | 08:17 PM
RadBOSS's Avatar
If you already have the adjustable bar I would install it and dial out that 1/4".
Old Feb 19, 2006 | 08:39 PM
tkogt's Avatar
just curious if the stiffer rear springs messed with the balance of the car in the corners?
im in the process of installing the full frpp suspension kit so ill be useing matched spring rates front and rear.
my first thought always goes to cornering balance.
it is possible that you may have made the car loose in high speed corners.
i would suggest you find the cars limits in a controlled manner.
(a suprise spin could be a really bad thing)
jay
Old Feb 19, 2006 | 08:42 PM
Stoenr's Avatar
I really havent noticed a difference other than if you hit a bump or crack in the road it will kick out the rear. but Ive noticed that from day one. I havent really pushed it that hard because my snow tires are on, but what I can tell it feels fine.
I cant wait to see it in spring when I put the 18's back on.
Old Feb 19, 2006 | 09:27 PM
Baginoman2's Avatar
<div class='quotetop'>QUOTE(Stoenr @ February 19, 2006, 9:45 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Wat do you mean by "kick out the rear" ?? Like tail whip? [img]style_emoticons/<#EMO_DIR#>/dunno.gif[/img]
Old Feb 19, 2006 | 09:33 PM
Stoenr's Avatar
I should have said hop, not kick out. That make more sense?
Old Feb 19, 2006 | 09:41 PM
Baginoman2's Avatar
so no loss of control?
Old Feb 19, 2006 | 09:55 PM
Stoenr's Avatar
I would have to answer no to that.
Old Feb 19, 2006 | 10:00 PM
Baginoman2's Avatar
<div class='quotetop'>QUOTE(Stoenr @ February 19, 2006, 10:58 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
sweet, hey Stoenr u ever gonna lower the front? [img]style_emoticons/<#EMO_DIR#>/dunno.gif[/img]
Old Feb 19, 2006 | 10:02 PM
Stoenr's Avatar
Its not planned at this time. Its time for some performance mods right now.
Old Feb 19, 2006 | 10:06 PM
Baginoman2's Avatar
sweettttt, whatcha got planned?
Old Feb 19, 2006 | 10:09 PM
Stoenr's Avatar
the basics really. CAI and tuner. Underdrive pulleys have been sitting at work for 2 weeks waiting for a slow day to install.
Old Feb 19, 2006 | 10:10 PM
Baginoman2's Avatar
nice man [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] Hey did u install the rear springs urself? If not how much did u get charged?
Old Feb 19, 2006 | 10:13 PM
Stoenr's Avatar
yeha I did them myself. took about 20 minutes tops.
I have a shop with all the tools and lifts tho.
Old Feb 19, 2006 | 10:14 PM
Baginoman2's Avatar
<div class='quotetop'>QUOTE(Stoenr @ February 19, 2006, 11:16 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
wow thats it?! You think the front would take longer?
Old Feb 20, 2006 | 08:06 AM
Stoenr's Avatar
Yes, much longer on the fronts. You need to pull the struts out on the front to change the springs. And then you can guarantee needing some sort of alignment.
