Ring and Pinion for Axle Whine TSB
Finally took my car into the dealership for the axle whine yesterday, they ordered the dampner kit as instructed by TSB 05-7-3
Took my car back today they put the dampner on and determined the whine was still unacceptable and have ordered a ring and pinion set from Ford.
Anyone else have this as the outcome of their rear axle whine service?
That sucks. To bad you didn't tell them to order some 4.10s for you while they were doing it. The labor is the most expensive part of that and since they already have to replace it, it should have been free.
That's what I did with my '98.... no noise, but the pinion seal was leaking. They wanted to just punch in a new seal, and I told them "heck no".... there was a strip on the undercarriage right above the yolk that indicated it had happened for some time.... didn't notice until the car sat in the garage for a week. Anyways... I'm glad I made them tear it appart, because the carrier bearings were shot and the carrier pin was sheered. ANYWAYS.... I had them swap out the 2.73s for a set of 3.73s.. offered to pay for parts. My buddy swung the deal and all I had to pay for was a new speedo gear.
Originally posted by dustindu4@October 13, 2005, 1:14 PM
yeah you should have gotten 4.10s man
I'll be happy with the stock replacment parts for free. What is the stock pinion gear ratio?
Originally posted by TehSLeeper@October 13, 2005, 2:42 PM
I heard the FRPP gears don't give any whine, while the motive ones a prone to gear whine.
Only difference is the name on the box.
Well I had the Motive 4.10's and they had some pretty annoying whine on deceleration from around 55-38mph. The installer tried to adjust them but had no luck and was unable to affect the noise. They went ahead and put in the FRPP 4.10's and guess what.....no more whine. There is still a little whine but you wouldn't notice it unless you listened carefully and knew what it was. Great shop BTW, no charge for the adjustment or install of the FRPP gears, they only charged me the difference in cost between the Motives and FRPP's.
Originally posted by FinlayZJ@October 14, 2005, 12:00 PM
If set up correctly, no gear set should whine. Period.
No more whining. WOOHOOO!
![Banana](https://themustangsource.com/forums/images/smilies/banana.gif)
So if anyone out that has the whine just take it in, if your dealership is as good as mine they will fix it right up.
Rando
8/25/21 11:12 AM
9/24/15 08:15 PM
9/10/15 12:44 PM
