Rim bolt pattern and offset
Old May 2, 2005 | 05:13 PM
NickS's Avatar
I think I've finally made up my mind and am thinking about purchasing these Falken Koblenz wheels. I don't know what bolt pattern and offset ill need though. I thought the bolt pattern was something like 5-114, but im not sure. Any help would be much appreciated. Thanks guys
Here are the sizes of the 19s:
75433031 machine/gm 19x10.5 5-114.3 30mm
75433032 machine/gm 19x10.5 5-114.3 10mm
75433007 machine/gm 19x8.5 5-120 38mm
75433008 machine/gm 19x8.5 5-112 35mm
75433009 machine/gm 19x8.5 5-114.3 35mm
75433010 machine/gm 19x8.5 5-100 35mm
75433011 machine/gm 19x8.5 5-114.3 25mm
75433012 machine/gm 19x9.5 5-120 45mm
75433013 machine/gm 19x9.5 5-112 35mm
75433014 machine/gm 19x9.5 5-114.3 42mm
75433015 machine/gm 19x9.5 5-114.3 35mm
Old May 2, 2005 | 05:37 PM
NickS's Avatar
I forgot to mention that I want to wrap them in BFGoodrich G-Force KDW2, probably P255/45ZR19, so would 19 x 9.5†be the best size to use? Thanks
Old May 2, 2005 | 07:11 PM
SRQ05GT's Avatar
The bolt pattern is 5x4.5 (5x114.3). Im running 19x8.5 front with 245-40ZR19 Front and 19x9.5 with 285-35ZR19 Rear. No fit problems and they are the same diameter and match the orginal tire size. Not sure of the offset....Org is 45.
Old May 3, 2005 | 03:29 PM
NickS's Avatar
Thanks SRQ05GT. Could you send me some pics of your car? I'm curious to see what this size looks like. Thanks again
cozyp828
Dec 13, 2017 05:53 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
