Rich running engine
Not sure if I'd like the inside to be black so it always looks dirty. I wipe the inside of my Magnaflow tips down every evening and they are always nice and shiny for the next morning. It only takes a few seconds.
Bottom line is I guess it's good for the aftermarket - with a computer tune you can get 15-20 HP out of the box, not bad if you ask me.
Regarding comment on "sports" cars that are running on high octane fuel.
I considered and drove the G35 coupe, the 330Ci BMW, the Acura TL, and a few other sporty imports. All of them REQUIRED premium fuel. However, they all used small displacement engines with compression ratios in excess of 10.5:1. The higher octane fuel was required due to the higher compression ratios and the tune used to achieve the hp output. The Mustang can achieve 300 hp on 87 octane due to it's larger displacement and dispite it's low compresion ratio. The nice thing is that while the imports are maxed out on hp without turbo or sc add-ons, the Mustang can be modded and retuned for additional hp using premium fuels. With the Mustang you get a choice, with the imporrts you must use premium.
John
John
Mackitude
Aug 13, 2015 01:05 PM
roushcollection
Jul 28, 2015 02:08 PM
