Review: Steeda Under Pullies
I have had the Steeda Underdrive Pulleys installed and had some info for you:
Please visit My Car Domain Webpage
Visit page 5 for the Underdrive Pulleys (today 12/3)
Visit page 7 for the Billit Interior Upgrades (today 12/3)
I am OVERLY Pleased with the performace ... Great Bolt On.
-Bryan
-Bryan
Originally posted by steal101@December 3, 2004, 5:15 PM
Is there any thing bad to having the pulleys on the car?
Originally posted by dannygat+December 3, 2004, 7:19 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (dannygat @ December 3, 2004, 7:19 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-steal101@December 3, 2004, 5:15 PM
I was thinking of some BS like that. AS long as the car doesn't blow up I'm happy.
Well I dont know the ratios, BUT, the Harmonic balancer is smaller, BUT the water pulley is larger. SO the only thing that slows down is the AC, power steering and alternator. (basically)
I really like your pages, very informative! If I could feel a change in the horsepower on my car when I had my pulleys installed I could only imagine with your car. Have fun, at this rate by the time spring roles around your car will be ready for shows.
Bryan
Please ask the shop what kind of puller they used to remove the crank pulley. I am going to assume it was one that has grips you place behind the balancer & the press section will go against the crank. Also what size if possible. Looks tight down there.
Did you use the stock belt or do you have to change to a different size?
On your heat shield. A quick fix could be a piece of roll bar padding that you can place between the water hose & intake hose. The padding can be cut & shaped to fit either hose & can then be attached with a wire tie. Will not conduct heat & is fire proof.
Thx again for all your info.
Originally posted by PONY XPRESS@December 4, 2004, 6:59 AM
Bryan
Bryan
I will give the rollbar padding a try today. You think I can pickup some of that padding like at Lowes ?
Also, I am going to baclout my back trunk between the taillights
I hope it works out well.Thanks for your help
-Bryan
Bryan
The Hot Rod shop should have a piece of padding kicking around. You will only need a short piece to cover the water hose.
If not Lowes may have something you can use, get black so you don't see it.
I'm having Boss stripes done soon hopefully & I also want to black out the back. Pics please.
Thank you Bryan for your reviews its been a big help! B) For the radiator hose isue I went with header high heat tape. It seems to have worked pretty well.I just wraped the hose under the air intake tube. Im curious to see the MMR race upgrade,If it will allow more space between the hose/air tube?
