Rev Limiter
Rev Limiter
I was wondering if manual transmission cars have rev limiters? Can you put your foot in it and damage the engine by exceeding the redline or is there built in protection? Kind of a basic question but I have never seen it addressed here.
Plus, I think the Ford computer still tries to slowly pull power as you near the limit before the abrubt cut out that you feel at the stock 6250 setting. Power actually starts getting pulled away at 6000. Sort of softens the blow to the drive train.
No real need to keep it up that high anyway as the horse power curve starts falling off before 6000 anyway.
I haven't run her up that high yet but from what I've read, 6800 should not be too high for occasional use (I would not be comfortable running flat out for a long time at 6800) after you have the car broken in for a while.
I'll check back later!
Thanks,
Russ
The real reason for bumping up the rev limiter is to avoid the "I'm such a dumb-a$$" feeling when you experience the limiter induced nose-dive when you out floggin' your Stang.
I have hit the limiter on the track when she was stock. It hits hard at 6200 rpm or so. It throws you forward in the seat and the first thing I thought was "Oh sh*t! I broke something" and "the wife's gona kill me." That was followed by "Nah, I'm just an idiot."
While the stock Ford valve train is said to be able to handle rpms ofver 6250 after an appropriate break-in, it takes more than a CAI and tuner to take full advantage of the rpms above 6000. On the track after I installed my CAI and tune from Brenspeed, I managed the 1/4 mile in 13.4 seconds at 105 mph, in 3rd gear at about 6200 rpm (03 octane tune, stock street radials and stock 3.55 gears). 2nd gear at about 6000 rpm puts you in the > 60 mph range. There is still power in this rpm range but it is on the downward slope of the HP and TQ curves. Staying on it much farther over 6000 is a waste of time on the drag strip for me. I expect to dyno this set-up in the next few weeks and I'll post back after I do.
Check out my video I made with Doug's 91 Race Tune and see/hear for yourself.
video thread
Cobiecane
Oct 23, 2015 08:44 AM
