RET in Downey, CA tunes my car and.....
Old Jun 21, 2007 | 11:42 PM
SilverPOISON's Avatar
I got Greg from RET tune my car, I have a KB @ 13 psi.
He did a very conservative tune since is my DD. The numbers are
492/468
The car is a Beast, I am posting a graph with the previous tune. It was on 15psi and now is at 13 and making more power and torque..
The first video is the Dyno tune and the second one is a preview of the race tune...
Street tune 492/468
Race Tune Preview...
Old Jun 22, 2007 | 03:28 AM
The_Joker's Avatar
Did RET install the blower also or did they just do the tune? And was the car tuned somewhere else befor you went t RET?
Old Jun 22, 2007 | 10:11 AM
freebass55's Avatar
RET FTW!
Car sounds like a beast, SP.
Old Jun 22, 2007 | 10:23 AM
I installed the blower a while back. I have seen them intalling blowers and let me tell you, Greg does some clean *** intalls.
The car was tuned at another shop before, greg is 5 min away from my house vrs the other shop 2 hours or more depending on traffic.
Old Jun 22, 2007 | 10:57 AM
lodom's Avatar
Sounds great, and very impressive numbers, especially on less boost
Old Jun 22, 2007 | 01:08 PM
don_w's Avatar
Eduardo... I was at Irwindale last night and was hoping to see you there. I wanted to see how your car ran on the track.
Old Jun 22, 2007 | 02:38 PM
We were testing the car and my belt got ****ed on the two ribs close to the engine, It seams like they were hitting where the stock idlers were before. we grinded down a lil the timing cover and now is working great, for my bad luck napa didn't have more belts for me. I ordered 3 more belts, BTW what size belt are you runing?? HAve you tried to play with the gripper plate to tight the belt a lil.
Old Jun 22, 2007 | 02:40 PM
I added since the last tune LT's, 60 pound injectors and the 8 rib.
Old Jun 22, 2007 | 03:26 PM
don_w's Avatar
I'm running the 122.3" belt, with no slippage at all.
Old Jun 22, 2007 | 08:31 PM
JedCranium's Avatar
Nice performance spec's! I'm one week away from my KB install I decided to go with 12psi since the bottom end of the engine is stock. Even with that I will probably exceed the recommended HP for the pistons of 450 HP. My goal is 500 RWH when all is said and done. Eduardo that tank on the right side of your engine compartment did you upgrade that tank for your KB? If so can you share some info on it. I like how it looks, I think the KB tank is smaller and made of plastic yes?
Bill
Old Jun 22, 2007 | 08:47 PM
In fact I modified a Canton aluminum tank. I welded two 2 inch aluminm strips to it and Use a hole that is on top of the fender, you need to eliminate the windshield washer fluid container.
Old Jun 22, 2007 | 09:44 PM
JonCo's Avatar
All on stock internals? Brave man.
Awsome numbers
Old Jun 22, 2007 | 09:49 PM
kevinb120's Avatar
Look very carefully at his sig
Old Jun 22, 2007 | 09:53 PM
JonCo's Avatar
Haha
Old Jun 24, 2007 | 02:28 PM
LOL... I have a built short block with low compression, lower than stock. Upgraded valve springs and that's it. Maybe I get ported heads and stage 3 cams next year.
Mustang259
'10-14 Interior and Audio
74
Mar 25, 2016 04:27 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
HMR-TYM
Jul 31, 2015 10:39 AM
dohc97
Jul 26, 2015 09:16 AM
2015turbostang
Ecoboost
Jul 21, 2015 11:58 AM
