Requesting, kicker removal instructions.
Old Aug 9, 2005 | 01:51 PM
klous's Avatar
I need removal instructions for the exterior kicker trim below the doors. The piece on the driver side is popping off near the rear tire because one of the plastic push pegs Ford uses to hold this on has popped out.
Ive seen people post before from Fords service instructions pdf documentation, that would be preferable but will settle instructions from someone who has removed them for replacement.
I prefer to do this work myself as it avoids the dealership monkeys messing with my seat, getting fingerprints in/on the car.
**EDIT**
I know some people here also might have access to the ford parts database which includes component diagrams, this might also be of assistance. So Im also asking for that from anyone with access thats willing to help.
Old Aug 9, 2005 | 03:25 PM
flamin ponyexpress's Avatar
**EDIT**
There's instructions on how to do this in on eof the other threads, But I have done mine myself, It's not hard you will need to remove the plastic push pins at the front and rear of the kicker panel, then there is about five or six or a little more under the kicker panel, you will need to jack the car to get access to them, after you pull them out at the bottom of the panel. give the kicker a little tug around the top of the kickers. working your way down the kicker at the top, pulling on kicker as you do this . It should come off. Good luck! hope this helps...
Old Aug 9, 2005 | 03:35 PM
169stang's Avatar
are you talking about this piece
Old Aug 9, 2005 | 03:42 PM
klous's Avatar
Thats the piece, awesome.
Thanks man, thats exactly what I needed, this will work out great.
Old Aug 9, 2005 | 04:06 PM
mikeelia's Avatar
Man, I wish I had access to that online Ford OASIS program...
Mike Elia
Old Aug 9, 2005 | 04:11 PM
169stang's Avatar
You can buy a CD on ebay for $25-$50. Depending on how many are available.
Old Aug 9, 2005 | 04:27 PM
mikeelia's Avatar
Thanks Dave!
Mike Elia
AJ_Trevino15
Sep 28, 2015 07:51 AM
TMDM
Sep 24, 2015 07:00 PM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
