Removing the trap in the air intake
Old Apr 30, 2005 | 07:22 PM
DaTT(1sK)'s Avatar
Do I need a tune if I remove this?
Old Apr 30, 2005 | 09:22 PM
Dysan's Avatar
Nope...all you want to do is follow the information in the manual about disconnecting the battery. I believe you'll want to disconnect the battery for approx 20 minutes...while that's sitting you can remove the trap. hook the battery back up, start the car and let it idle until the engine temp is up to normal, then turn the a/c on and drive for about 10 miles..that will make the computer adjust for it being removed. I did it myself and have had no problems.
Hope this helped.
Old Apr 30, 2005 | 10:48 PM
daveyramone's Avatar
What's the deal with having the AC on? :scratch:
Old Apr 30, 2005 | 11:00 PM
Dysan's Avatar
got me..but it's on page 205 from the manual...here's a copy of the text...
"Because your vehicle’s engine is electronically controlled by a computer,
some control conditions are maintained by power from the battery. When
the battery is disconnected or a new battery is installed, the engine must
relearn its idle and fuel trim strategy for optimum driveability and
performance. To begin this process:
1. With the vehicle at a complete stop, set the parking brake.
2. Put the gearshift in P (Park) (automatic transmission) or the neutral
position (manual transmission), turn off all accessories and start the
engine.
3. Run the engine until it reaches normal operating temperature.
4. Allow the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute.
6. Drive the vehicle to complete the relearning process.
• The vehicle may need to be driven 10 miles (16 km) or more to
relearn the idle and fuel trim strategy.
• If you do not allow the engine to relearn its idle trim, the idle
quality of your vehicle may be adversely affected until the idle
trim is eventually relearned.
When the battery is disconnected or a new battery installed, the
transmission must relearn its adaptive strategy. As a result of this, the
transmission may shift firmly. This operation is considered normal and
Maintenance and Specifications
205
will not affect function or durability of the transmission. Over time the
adaptive learning process will fully update transmission operation to its
optimum shift feel."
Old May 1, 2005 | 08:06 AM
mikem's Avatar
I never did this when i removed it.Ran just fine.
Old May 1, 2005 | 08:14 AM
DaTT(1sK)'s Avatar
Was the HC trap the first thing you removed, before all your mods? I want to remove it, but I don't have a tuner as of yet.
Old May 1, 2005 | 08:16 AM
adrenalin's Avatar
HC trap was the first mod I did because it didn't cost me a penny. I didn't even disconnect the battery. I just removed the trap, hooked the tube back up and away I went. Never had a problem after that, well, at least not because of the trap.
Old May 1, 2005 | 08:20 AM
DaTT(1sK)'s Avatar
Looks like I have a little project for today. Noticeable difference?
Old May 1, 2005 | 08:30 AM
Dysan's Avatar
I really didn't notice anything. I have just ordered a diablo predator & I will be ordering the JLT CAI once Jay gets some stock in...he's waiting on some parts that will be in on May 9th. I'm sooo excited to try the tuner & CAI!!
Old May 1, 2005 | 09:51 AM
adrenalin's Avatar
Before doing any other mods I drove over 1,000 miles after removing the HC trap and did notice better gas mileage.
Old May 1, 2005 | 12:00 PM
pittperson's Avatar
Call me crazy but I swear I have just a tad bit more power down low after remove the HC trap. And just last weekend I made a trip from Baltimore to Pittsburgh and got 24 mpg...and I'm a left lane driver
Old May 1, 2005 | 01:06 PM
blk05stang's Avatar
How do you remove this thing? I took apart the tube going into the air filter to check out this trap and it's really wedged in there and wouldn't budge. Do you have to cut it out or something?
Old May 1, 2005 | 02:22 PM
mikem's Avatar
Grab it with needle nose pliers and spin it out.
pittperson's Avatar
needle nose pliers, some yanking, and a bit of patience. Grab the outer edge of the HC trap with the pilers and just slowly work it out. Once you get it out from behind the rubber lip it will get easier and easier.
Old May 1, 2005 | 02:58 PM
blk05stang's Avatar
Cool thanks!
Old May 1, 2005 | 03:55 PM
frdtch05gt's Avatar
Will the stock intake make any kind of audible noise with this part removed? I will probably take mine out this week.
Old May 1, 2005 | 04:10 PM
Sonic05's Avatar
How's this for odd . . . my car doesn't have the trap! I was feeling the hose, and there is nothing in it. So I pulled the air box lid off, and I can't see anything in the hose. Anybody else with recent build dates check?
Old May 1, 2005 | 05:39 PM
DaTT(1sK)'s Avatar
Your gas mileage improves gradually as your odometer climbs. Your removal of the HC trap may or may not have contributed to this.
DaTT(1sK)'s Avatar
I am also curious to this.
Old May 1, 2005 | 05:44 PM
pittperson's Avatar
I guess this just shows how much of a crock this HC trap really is?
