Remove the air conditioning, anyone did it?
Old Aug 9, 2013 | 04:06 AM
F_Serra's Avatar
Hello guys, im thinking in remove the all air conditioning system on my 06 GT in order to save weight and because i don't use it at all.. anyone did it? How complicated can it be? If i just remove it there will be any error light coming up?
thank you
Old Aug 9, 2013 | 12:40 PM
67Drewstang's Avatar
You realize the defrost system uses the air conditioner, right? That means if your windshield ever fogs up, you will be out of luck...
Old Aug 9, 2013 | 01:07 PM
wallace's Avatar
05-09 MUSTANG A/C DELETE PULLEY
Priced @ 39.99 / 49.99
Easy!
I'm guessing any guy who wants to remove the AC unit isn't worried about a little window fog.
If you're serious about weight saving, then an aluminum driveshft is a must.
Just installed a dynotech and man what a difference!
Old Aug 9, 2013 | 03:55 PM
F_Serra's Avatar
Well i can clean it by hand ahha thank you wallace i will search for that! and about that driveshaft, yep already on my mod list! Although i was thinking on the steeda one.. that dinotech one, are you happy with it?
Old Aug 9, 2013 | 08:06 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
Back in the old days, like the 1970s .... the AC was not used at all for the defrost. It was very common for an AC to not be used 8 - 9 months and longer some years. The defrost just used warm or hot air same as heat.
And then there are all those cars / trucks that never had AC and still defrost worked just dandy.
It is because the AC dehumidifies as well as cools that the AC was then tied into the defrost, just made it work faster and by doing so, also ensured that the AC got used some year round .... better for compressor seals.
My 1977 F-150 factory AC / heater did not originally use AC with defrost ..... so I simply added a toggle to switch on the AC clutch if desired for faster defrost or even if I want cold air out heat floor ducts (turn temp to cold and flip swith and run compressor with heater) ..... it does speed it up .... but defrost works without AC too.
dblhelx
Oct 6, 2015 08:08 PM
Allen Hanback
Sep 14, 2015 04:37 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
