Regular Hurst vs Billet Hurst
Personally I'd say don't bother with hurst at all and get the best shifter on the market the MGW. BUT if you must have hurst I had the regular comp plus one and I can tell you it was a piece of crap. I haven't seen the billet one but anyone I've talked to that switched from the comp plus to the billet said it was a worthwhile improvement.
I like my non-billet unit fine and it's certainly strong enough for my style of driving. I've never shifted the billet unit, so I can't tell you if billet is better, but, I wouldn't remove my "standard" Hurst for the billet piece either.
Look Anthony k, he asked a question on a forum and 2kanchoo gave him an answer. If you don't like it too bad. What do you work for Hurst or something? Grow up.
Sorry I forget not everyone has seen mine or others threads where we go into depth about how it would bind horribly when powershifting at high rpm's, had no adjustability, and had very poor craftsmanship. I had pictures of how the shift handle didn't even begin to properly bolt up and would continually come loose and allow a good 3/4'' + wobble of the shift ****. If I knew what I know now I wouldn't have wasted my money. As far as I'm concerned crap doesn't even begin to describe it, especially when there are other shifters out there that are so much more superior in every facet. The mgw is the most adjustable of any shifter out there ( adjustable throw range anywhere from stock to about 40%. Also adjustable **** height AND angle) it is also the most over engineered, over built, shifter out there. I also forgot to mention that I've tried the pro 5.0 and steeda triax shifters out as well.
The throw is 40% less on both pieces. Billet is prettier, but you don't see it after it's installed.
i have the standard hurst and its badass.... no problems here. no reason to get the billet.
Hurst FTW. i have felt several other shifters and im glad i got the hurst... suits me just fine.
I am happy with my Hurst comp. I paid only $100 shipped for it. According to the seller, it had only 300 miles on it. He sold it because he was doing a man to auto swap. It was noisy at first, but dynomatting took care of the problem.
I have to ask if all (most) of the reported hurst issues are install related? I mean if it was such an inferior product wouldn't there be an overwhelming outcry of Shelby GT owners?
I have only heard of individuals that installed it themsleves having problems. Now maybe that's an engineering issue but I do find it curious.
+1 MGW, everything else is just a shifter
Jed
There was also a run of these shifters that had a bearing problem that Hurst addressed through warranty exchange and design changes.
Just a question. Any of you guys that have the comp plus and like it really bag the shlt out of it? I'm talking 6000-7000rpm powershifting. No lifting your gas pedal foot, slamming it into 2nd and 3rd as hard and fast as you possibly can while being just as quick with the clutch, type shifts. Cause honestly if you are getting away with it I am honestly happy for you. Aside from the shifter arm problem which I heard they fixed later, even tho it was so horrendous it shouldn't have even passed R&D, let alone engineering, let alone quality control. I probably wouldn't have gotten rid of it, if it wasn't nearly impossible 75% of the time (for me) to get it into gear when hammering on it.
But then again I would have missed out on all the adjustability so I guess it's for the best. I did keep my white hurst **** to use with my mgw tho.
Well I had the Hurst Comp bearing problem. Pulled it from the car got the MGW and also kept my Hurst shifter ****. I never gave my opinion above because I've never used the Hurst Billet. I do know that my Hurst Comp came to me defective and my MGW didn't. The Hurst vs. MGW arguement has been done before. I hear stories of people going from Hurst to MGW, but I've never heard of the MGW guy going to a Hurst.
I don't know if that means anything.
Back to the original question, I don't know, so I'll leave it at that.
But then again I would have missed out on all the adjustability so I guess it's for the best. I did keep my white hurst **** to use with my mgw tho.![Headbang](https://themustangsource.com/forums/images/smilies/headbang.gif)
