Rear suspension
Rear suspension
Want to hook better at the track. I don't care about turning or ride comfort. What parts, brands, etc do you guys suggest. I know I'll need upper and lower control arms. What about shocks, braces, etc? Thanks guys
This question is really going to depend on your budget and what you already have on the car. I will assume you have no other components on the car at this time.
You could definitely improve your numbers with the following items from Steeda Autosports:
UCA/LCA
Adjustable Panhard Bar
Shocks/Struts
Down the road you can add the following:
Springs
Sway Bars
HD Struts
You could definitely save by doing most of this stuff at the same time. For example, labor would be cheaper if you did springs and shocks/struts at the same time.
We have a shop in Pompano so if you would like me to get the boys at the shop to write up a quote for parts and labor then I can help provide that.
Let me know your thoughts..
Here is a good video that was done with upgrading a 2011 suspension.
http://www.steedablog.com/2011/10/mm...ck-with-a-5-0/
UCA/LCA
Shocks/Struts
Springs
Sway Bars
HD Struts
UCA/LCA
Shocks/Struts
Springs
Sway Bars
HD Struts
UCA/LCA
Shocks/Struts
Springs
Sway Bars
HD Struts
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 8, 2015 10:45 AM
