Rattling After Spring/LCA Installation
Old Jan 28, 2006 | 09:19 PM
Bags2005's Avatar
I installed the eibach pro-kit, and the BMR adjustable LCAs with the rod-end at one end and the poly bushing at the other end. Now I have a very loud rattle coming from the rear suspension. I put the car back up on jackstands and retorqued everything, but the rattle persists. I thought you guys may have a different idea on what it may be. Any input is appreciated. Thanks in advance.
Ryan
Old Jan 31, 2006 | 01:27 PM
2MFF's Avatar
Is it a rattle or a "creeking" sound as you go over bumps? I found that putting some teflon based lube on the rod end help quiet down those solid ends.
Old Jan 31, 2006 | 02:19 PM
ren274u's Avatar
my guess is the lca
Old Jan 31, 2006 | 02:55 PM
Bags2005's Avatar
it's definitely a rattle, sounds almost like something is loose, but I checked and everything seems OK. Anyone else with ideas. Off to check under the car again.
Old Jan 31, 2006 | 06:45 PM
Bags2005's Avatar
I went out and gave the LCAs a good tug, and they move ever so slightly. I torqued them according to the BMR instructions, but I also remember reading that they should be torqued to 130 ft/lbs instead of the instructed 75.
Old Jan 31, 2006 | 06:57 PM
2MFF's Avatar
Try the lube and let us know. I too thought my LCAs were loose or the bracket broke. I checked them and everything was fine. I added a little teflon lube to the rod ends and no more noise.
Old Feb 5, 2006 | 05:04 AM
u-got-stang's Avatar
Did you trim the rear bump stops during installation? You could just slightly be hitting up against them...
khoy37
Sep 15, 2015 07:10 PM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
